fteixeira |
Newbie ![]() Group: Members Posts: 32 Joined: 25-February 11 From: Santa Clara, CA Member No.: 12,754 Region Association: None ![]() |
Anyone can tell me the diameter of the original inner mount trailing arm hole? I'm redoing my rear suspension and found some slight ovaling. Looks like I'll have to go the weld/re-drill route.
Any other tips for doing this repair properly? Below is a link to a pic from another thread that Jeffs9146 posted. Thanks! F Teixeira Oval rear mount |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
Anyone can tell me the diameter of the original inner mount trailing arm hole? I'm redoing my rear suspension and found some slight ovaling. Looks like I'll have to go the weld/re-drill route. Any other tips for doing this repair properly? Below is a link to a pic from another thread that Jeffs9146 posted. Thanks! F Teixeira Oval rear mount Just mic the trailing arm bolt and go a tad larger! That's what I did! |
fteixeira |
Thanks Jeff. I just wanted to know what the factory did. I'm measuring 13.82mm on one and 13.90mm on the other with my calipers. Looks like 9/16"drill will give me 0.020" slop total... maybe slightly more with some wobble during drilling. Hopefully, that will work.
Thanks! F Teixeira |
Jeffs9146 |
The key is keeping the hole in the same location so the suspension geometry remains the same! I drew an X on the ear to mark the exact center spot. After welding I connected the X and I drilled a small pilot hole in the spot where the lines crossed. Then I used a universal bit to the size I wanted it!
Lo-Fi Version | Time is now: 8th July 2025 - 06:41 PM |
