> replace my alternator?, what do you think
rwilner
post Oct 8 2011, 05:37 PM
No Ghosts in the Machine
I have my engine out and removed my alternator to replace the wiring harness. The alternator works fine, but it will never be easier to replace it than right now.
What would you do?
r_towle
post Oct 8 2011, 05:52 PM
Custom Member
while it does suck to replace in the car...it can be done in about 30 minutes from underneath...provided all your heater pipes can be removed easily...
If you want to replace it...consider having the guys are Chelmsford Auto Electric rebuild it for you...
The stuff coming in from overseas has alot of quality issues...mainly starters and alternators.
Rich
ejm
post Oct 8 2011, 05:54 PM
I can see the light at the end of the tunnel
I would wait for it to fail. The quality of rebuilds can be hit or miss and you may find yourself replacing it sooner than if you had kept the old one.
rwilner
post Oct 8 2011, 07:07 PM
with this car, I constantly flip back and forth between "if it ain't broke don't fix it" and "while I'm in there..."
Think i'll leave this one alone.
thanks guys
Rich
TheCabinetmaker
post Oct 9 2011, 07:49 AM
I drive my car everyday
I agree. Leave it alone.
rwilner
post Oct 9 2011, 07:51 AM
QUOTE(vsg914 @ Oct 9 2011, 09:49 AM) *
I reinstalled it last night, but not before cleaning up the mounting bracket so it grounds properly (IMG:style_emoticons/default/biggrin.gif)
PanelBilly
post Oct 9 2011, 06:24 PM
Did you pull the cover and check the electrical conections inside. The wire strands on mine had corroded and the currrent was all flowing through 4 "threads" Jeff Bowlsby has new ones and its an easy to do on the bench.
rwilner
post Oct 9 2011, 06:25 PM
QUOTE(PanelBilly @ Oct 9 2011, 08:24 PM) *
by "inside" do you mean the wiring harness or the parts internal to the alternator?
PanelBilly
post Oct 9 2011, 06:42 PM
the back cover comes off and there is a plug in connector and a wire with a nut and bolt connection, if I recall correctly
- Lo-Fi Version Time is now: 18th September 2026 - 01:27 AM
