> HELP! cylinder #3's got the devil in him
hasaramat
post Oct 10 2011, 10:53 PM
Well after about 12 years sitting the 914 finally came out of the garage and ran up and down the street!!Attached Image
It runs but a bit on the rough side. I cannot get cylinder number three to wake up. When I pull the injector plug off the other three cylinders the engine "lumbers" but with number three nothing happens. Here is what I have done:
1- re-adjusted valves the captn's way, didn't need it
2- pulled the injectors and check for spray
3- compression test 118 psi
4- pulled the spark plug and checked for spark (it got me)
5- put #3 injector wire on #4 to make sure there was a signal
6- checked ground to number three injector wires
7- put another injector in #3
8- motor runs with no knocking "other than type IV noise"
9- when I drive it the motor seems to wake up at about 3000 rpm
10- new NGK plugs
It is a 1974 2.0 with euro pistons and everything else is stock.
I hope someone can give me a "OOH I haven't tried that"
Any help would be gratefully accepted.
pcar916
post Oct 11 2011, 05:00 AM
Is that a Lola?
Are the injectors spraying the same amount of fuel?
After sitting for so long I've had to get them professionally cleaned. That goes for both electrical and CIS (K-jetronic) types.
If you have air, gas, and fire and no exhaust obstruction) then one of them is off or out of sync.
That said, I have no experience with those computers and whether or not they're capable of making this happen.
Bartlett 914
post Oct 11 2011, 05:27 AM
check the compression on all cylinders.
willamp
post Oct 11 2011, 06:36 AM
Drivin' in Texas Hill Country
Even though you got a spark on number 3 wire I would suggest to swap or replace the wire with a different one. I had intermittent problems recently that turned out to be a bad spark plug wire. I think even though it would allow a spark it was weak and so the cylinder wouldn't fire under all conditions. It's a cheap thing to try.
FourBlades
post Oct 11 2011, 06:43 AM
From Wreck to Rockin
Spark color should be blue/white and not red or orange.
John
hasaramat
post Oct 11 2011, 07:28 AM
The spark color did seem a little orange. I will change the cap, rotor and wire to see if that will help. I did check compression in #4 and it was 120 psi but I should check #1 and #2.
- Lo-Fi Version Time is now: 5th July 2025 - 09:46 PM
