> Dremel Grinding Tool, which bit works best on welds?
seanery
post Jul 28 2004, 08:20 PM
waiting to rebuild whitey!
I'm grinding mild steel welds on my bike to get it ready for plating.
I used this bit this evening. It only lasted an hour or hour and a half.
(IMG:http://dremel.com/html/images/products/bits/large/194.gif)
Is there a better bit?
I've got some abrasive tips for the air powered die grinder, but I don't think the compressor will keep up with hours of grinding.
TimT
post Jul 28 2004, 08:38 PM
retired
Probably the best would be a diamond impregnated burr. But if you keep going with the steel burrs use plenty of coolant . dip the bit in an emulsion of tranny fluid and water then grind, then dip, then grind
kafermeister
post Jul 28 2004, 08:48 PM
Hmm. I've never had much luck w/Dremel for grinding welds. Of course, I'm a amateur welder and I need lots of cleanup to make my work look presentable. (IMG:style_emoticons/default/biggrin.gif)
Anyway, I like to use a pneumatic die grinder with a cutoff disk to slice through the welds to set my depth. Then I use a 4" angel grinder w/abrasive grinding disk and grind down the ridges.
Strangely what I've had the most success with is a plain pneumatic single action sander with 8" 25 grit disk. But it eats the metal you're trying to save as well. It's not good at localizing your grinding area.
Good luck!
Rick
seanery
post Jul 28 2004, 09:06 PM
yeah, I'm trying to make it pretty. I want to be able to remove material where I want to only.
This is what I've found at the Dremel Webpage. Would these be better than Aluminum Oxide?
bondo
post Jul 28 2004, 09:27 PM
Carbide cutters for a die grinder are the best I've used.. they really hog out the material, you can litterally carve out the bead from an inside corner (like inside the front trunk weatherstripping groove for instance). Unfortunately they're pretty expensive. They also spray you with little metal shavings that are VERY sharp, and get under your skin quite nicely.
Mueller
post Jul 28 2004, 09:31 PM
914 Freak!
Sean,
if you have the room, I think the small cutoff wheels are better and easier to control for removing material.
Mueller
post Jul 28 2004, 09:33 PM
914 Freak!
the problem with the carbide cutters is that it is very easy for the tool to "ran away" from you, or at least that is my experiance (too much coffee???)
bondo
post Jul 28 2004, 09:38 PM
QUOTE(Mueller @ Jul 28 2004, 08:33 PM)
I have more trouble with that using dremel tools than with die grinders.. not sure why.
lapuwali
post Jul 28 2004, 09:48 PM
Not another one!
My experience with the Dremel cutoff wheels is they don't last very long. The medium brown colored ones that look like something pressed together last only a few seconds cutting steel, and break very easily. The fabric-looking ones last longer, but still rarely more than a few minutes. You can actually watch the things shrink. You seem to remove about as much material off the wheel as you do steel from the weld...
There's a speed control you can get for a Dremel that will allow you to slow it down a good bit, which might help. I have a variable speed Ryobi with a flex shaft, and slower speeds seem to extend the life of cutters and grinders a bit, but only a bit. I think the slowest speed on this thing is still way too fast. My air grinder is quite a bit slower.
Mueller
post Jul 28 2004, 09:58 PM
914 Freak!
I had to use a dremel cutoff wheel last week to remove the head of a stripped CV joint bolt (IMG:style_emoticons/default/sad.gif)
thomasotten
post Jul 28 2004, 11:36 PM
I used the carbide tip to remove the jack post support on the passenger side of the teener. Worked great. You know, how you can hardly get to the top part of it, unless you remove the fender. Actually, part of it is still up there. (IMG:style_emoticons/default/rolleyes.gif) I used a RotoZip to cut most of the sheetmetal, but they wear out quick just like the Dremels.
IronHillRestorations
post Jul 29 2004, 12:02 AM
I. I. R. C.
Dremel is a good tool, but it's a hobby tool. If you use it for grinding welds it won't last very long. It's ok for small jobs, but it won't take much pressure.
I use the cut-off tool, a die grinder with carbide burrs, a 4" angle grinder, and a angle die grinder with roloc abrasive discs. Oh, and with eye protection, leather gloves, ear plugs, etc. Don't ask why...
PK (IMG:style_emoticons/default/cool.gif)
J P Stein
post Jul 29 2004, 02:05 AM
Irrelevant old fart
seanery
post Jul 29 2004, 08:11 AM
Alright, I'll give the air tools a shot. I hope it can keep up. (IMG:style_emoticons/default/wacko.gif)
jonwatts
post Jul 29 2004, 08:57 AM
no rules, just wrong
QUOTE(seanery @ Jul 29 2004, 06:11 AM)
Don't you want the justification to buy a new compressor?
I agree with the dremel assessment. They're great for close quarters work but for big jobs you'll go broke buying bits.
No personal experience on these but I saw a guy using them (or something like them) on Horsepower TV to remove trunk welds on an old Nova. The holes allow you to see where you're grinding.
(IMG:http://www.eastwoodco.com/images/us//local/products/detail/p18410.jpg)
Available at Eastwood
mightyohm
post Jul 29 2004, 09:34 AM
QUOTE(Mueller @ Jul 28 2004, 07:33 PM)
I have had this experience also. They tend to bite in and gouge at exactly the wrong time. I always end up making a bigger cut than I intended.
seanery
post Jul 29 2004, 11:03 AM
I found these and other bits at: American Carbide
What is meant by Standard Cut and Double Cut?
J P Stein
post Jul 29 2004, 11:57 AM
Irrelevant old fart
That cone radius ruby is one of those I use.....and that's a very good price. Dunno the difference...but at those prices, get one of each in the 1/4 or 5/16 size & see which you like. I get em' at a tool supply outfit up the street for about 12 bucks each. (IMG:style_emoticons/default/sad.gif)
seanery
post Jul 29 2004, 04:27 PM
I ended up buying these carbide bits from the vendor listed above. 8 bits delivered for $45. Seems like a deal to me (IMG:style_emoticons/default/biggrin.gif)
seanery
post Jul 29 2004, 04:31 PM
One more question, cutting oil or no cutting oil?
- Lo-Fi Version Time is now: 13th March 2026 - 11:52 AM
