| rjames |
Oct 21 2011, 10:48 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,485 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
I just received a new Sebro flywheel from Pelican.
The new flywheel has the proper A an B measurements, but 'C' is only 9mm. According to the chart below my flywheel is already out of spec by 2mm! Has anyone else encountered this? ![]() |
| mark21742 |
Oct 21 2011, 11:08 PM
Member ![]() ![]() Group: Members Posts: 162 Joined: 31-August 11 From: pa Member No.: 13,502 Region Association: North East States |
Is it made out of a better/ different alloy? That might be why....did you cal and ask them? That's what I would do first.
I do know that if your going for a lightened flywheel, slot of material has to be taken from somewhere to make a noticeble difference |
| sixnotfour |
Oct 22 2011, 05:30 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,421 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
9mm is correct for the type 4.
| jaxdream |
Oct 22 2011, 08:07 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
I just received a new Sebro flywheel from Pelican. The new flywheel has the proper A an B measurements, but 'C' is only 9mm. According to the chart below my flywheel is already out of spec by 2mm! Has anyone else encountered this? ![]() IIRC someone said that this is the spec chart was for a -6 flywheel , not the -4 flywheel. I could be wrong , but the thread concluded that the 11mm dimension was for the -6 not -4 . Maybe search would help. Jack |
| rjames |
Oct 22 2011, 09:03 AM
| Dave_Darling |
Oct 22 2011, 08:31 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,365 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Where does that information come from? I cannot find specs for the -4 flywheel; only for the -6 one.
--DD |
Lo-Fi Version | Time is now: 9th November 2026 - 03:06 PM |
