76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
It's time for the Ortega Run. I want to change the meeting spot, however. It makes it easier on newbies to find us. The new rendezvous point is the Home Depot parking lot. The Home Depot is located on Lake Shore at the intersection of the 15 and 74/Ortega Hi way/Central exit, NW quadrant.
Let's meet up 0630, depart 0645. Make our run thru the pass. Have breakfast at Denny's at the Ortega/5 intersection. Then the return leg. Maybe Eric will tailgate the two wheelers again. (IMG:style_emoticons/default/av-943.gif) EDIT: I see that the WX man is forecasting the wet stuff for Saturday so keep an eye on this post for updates. It might by a Friday nite call. If necessary, the run will be bumped to the 26th. (IMG:style_emoticons/default/driving.gif) |
phatnine11 |
Member ![]() ![]() Group: Members Posts: 286 Joined: 22-March 05 From: Rancho Cucamonga, CA Member No.: 3,798 ![]() |
Kent,
Sounds good! What day were you thinking about? Cesar |
Als914 |
Lighting my way ![]() ![]() Group: Members Posts: 330 Joined: 1-January 06 From: Hemet,Ca. Member No.: 5,346 Region Association: Southern California ![]() |
Kent, Sounds good! What day were you thinking about? Cesar Are you under your lift again Ceasar (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif) ? look at the title...Saturday, Nov.,19 (IMG:style_emoticons/default/poke.gif) |
phatnine11 |
Kent, Sounds good! What day were you thinking about? Cesar Are you under your lift again Ceasar (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif) ? look at the title...Saturday, Nov.,19 (IMG:style_emoticons/default/poke.gif) Which one Al?? (IMG:style_emoticons/default/biggrin.gif) |
silver74insocal |
Senior Member ![]() ![]() ![]() Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California ![]() |
(IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/driving.gif) i am on it!! after a little (IMG:style_emoticons/default/beer3.gif)
Dave |
shulew 3 |
desert toy ![]() Group: Members Posts: 30 Joined: 2-July 10 From: Palm Springs, CA Member No.: 11,902 Region Association: Southern California ![]() |
'73-914kid |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California ![]() ![]() |
Damn, Wish I could go... I have to fly out to St. Louis for a funeral unfortunately..
silver74insocal |
sorry to hear that Ethan, hope all is well.
Lou i am bringing the car, i only wish i could call it silver. thank god you cant see any part of the car while driving it.... (IMG:style_emoticons/default/biggrin.gif) |
Thestigz06 |
Aspiring Jarhead ![]() ![]() Group: Members Posts: 238 Joined: 22-February 11 From: Temecula, CA Member No.: 12,749 Region Association: Southern California ![]() |
I should make it assuming i have no work!
eric9144 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California ![]() ![]() |
I should be in for this one too, unless I get off my @ss and start the brake project (see slackers thread) (IMG:style_emoticons/default/lol-2.gif)
Wow, 6:30am, with the time change that's going to be like sleepin in late! |
914Bryan |
Member ![]() ![]() Group: Members Posts: 190 Joined: 6-June 11 From: Orange County Member No.: 13,162 Region Association: Southern California ![]() |
Im in! Maybe this time my coil wont jump from the bracket and ground out the engine! (IMG:style_emoticons/default/huh.gif) HAHA!
phatnine11 |
Im in! Maybe this time my coil wont jump from the bracket and ground out the engine! (IMG:style_emoticons/default/huh.gif) HAHA! Brian, Is that what happened? I thought it was the hose from the PCV system that caused your problem. By the way, you are not the first person that has had the coil issue! Cesar |
76-914 |
(IMG:style_emoticons/default/poke.gif) Isn't this usually when Enrique proclaims he will "be there"?
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
(IMG:style_emoticons/default/poke.gif) Isn't this usually when Enrique proclaims he will "be there"? I'll be there in place of him. (IMG:style_emoticons/default/laugh.gif) |
76-914 |
To tell the truth, It wouldn't surprise me one bit if you showed up Elliot. Now Enrique; well that's another story. (IMG:style_emoticons/default/lol-2.gif)
eric9144 |
Nearly 2 months since his last project update and the engine was already in the car (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/poke.gif) |
914Bryan |
Im in! Maybe this time my coil wont jump from the bracket and ground out the engine! (IMG:style_emoticons/default/huh.gif) HAHA! Brian, Is that what happened? I thought it was the hose from the PCV system that caused your problem. By the way, you are not the first person that has had the coil issue! Cesar Yes, closer inspection later showed that the coil had vibrated about half way out of the bracket, and one of the connectors was making contact where it shouldn't of been. One of the other guys that I met that day (Joe?) said to put some inner tube rubber around the coil, tighten it down and I can forget it. I was contemplating mounting the coil to the firewall but as long as it stays put, it shouldn't be an issue. BTW, the hose is getting a clamp on it too! HA! (IMG:style_emoticons/default/smash.gif) Fingers crossed!! |
914-300Hemi |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,356 Joined: 7-September 06 From: San Dimas, CA Member No.: 6,794 Region Association: Southern California ![]() ![]() |
I will also make the effort to get up early and join you guys. Car still without an engine and Tranny but will bring the GTI.
lagunero |
Donkey Member ![]() ![]() ![]() Group: Benefactors Posts: 1,042 Joined: 8-January 04 From: orange county,ca Member No.: 1,531 ![]() ![]() |
I'll know by Thursday.
wertygrog |
wertygrog ![]() ![]() Group: Members Posts: 428 Joined: 12-November 05 From: Long Beach, CA Member No.: 5,114 Region Association: Southern California ![]() |
Well guys...this will be the first one I miss since moving to socal. (IMG:style_emoticons/default/sad.gif)
Work is sending me to the UK until christmas so no 914 action for awhile. BUT I'LL BE BAAAACK!! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 05:26 PM |
