Need Dry Sump Info |
yeahmag |
Nov 8 2011, 05:36 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I'm almost sold on making my car dry sump and need some pointers. Things like:
* How big of a tank for a 2056 running the CB Dry Sump Pump? * How full to keep the tank? * How high/low does the bottom of the tank need to be in relation to the pump? I'll take any pointers you can give me. Thanks! -Aaron |
neilca |
Nov 8 2011, 07:58 PM
Member Group: Members Posts: 98 Joined: 26-July 05 From: Marietta, GA Member No.: 4,474 |
I'm almost sold on making my car dry sump and need some pointers. Things like: * How big of a tank for a 2056 running the CB Dry Sump Pump? * How full to keep the tank? * How high/low does the bottom of the tank need to be in relation to the pump? I'll take any pointers you can give me. Thanks! -Aaron I am running a six cylinder but some things are going to be the same. Use big lines. I have a -16 inlet from the tank and -12 cooler lines. I run a 3 gallon Patterson round tank. I fill it to 2/3 full. My tank is mounted where the pump is about even with the bottom of the tank. Hope that helps |
john rogers |
Nov 10 2011, 01:35 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
There are two places that oil tanks are generally mounted, some put it in the front trunk area and some in the rear trunk through a hole in the floor. I used the later with dash 16 suction and dash 12 to/from the front oil cooler. I used Earl's stainless oil lines as they are probably the safest to use. To get the length, use some garden hose to run exactly the path you want the final oil lines to run and then add a couple of extra feet to be safe. For oil level, generally there is a shelf about 1/3 the way down the tank and have oil just below that when the engine is hot. I also hooked in a large puke tank that vented the oil tank to collect vapor. and drain it after races.
A multi-stage external pump is the best way to go with 2 or 3 suctions and 1 pressure connection. The advantage of this is to gain a suction on the sump cover and one on each head so there are never any issues with oil build up in the valve covers or loss of oil pressure in long corners. Additionally there is a 4 to 5 HP gain if the case is run under a vacuum. The down side of this setup is that an upright fan/alternator must be used but then cooling is way better, especially for a race type of motor. Here is a picture of how my 914-6 was setup. Attached image(s) |
yeahmag |
Nov 20 2011, 03:46 PM
Got a tank from Blake! Looks real nice too. Where should I be running my oil temp sender now? I assume even with the CB Dry Sump Pump I plan on running that I'll have enough scavenge to make the stock 2L one inaccurate...
yeahmag |
Nov 21 2011, 06:47 PM
Just ordered the CB Dry Sump Pump... Wish me luck!
Lo-Fi Version | Time is now: 7th June 2024 - 07:28 AM |
