power without engine |
ruddyboys |
Aug 6 2004, 11:18 AM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
I have the engine out and while waiting for some parts, I figured I could check the front directional. I took the power wire from the bat to starter and covered it as to not hit the body and ground out. With battery connected to pos and neg I dont have any power? Do you need to have the engine in to get power?
Mueller |
Aug 6 2004, 11:21 AM
check your relay board, sounds like something is not connected...you should have 2 power lines going to relay board, and 2 power lines going directly into the drivers/pass compartment (I think, I could be totally wrong, LOL)
smrz914 |
Aug 6 2004, 12:05 PM
Soon to be brightening the life of the person behind you. Group: Members Posts: 456 Joined: 21-April 03 From: Pleasant Hill, CA or Chico, CA Member No.: 596 |
It might be me but i'm confused as to what you are trying to do. I think you are trying to check the turn signals. The engine is out of the car but the tranny is still in, or the engine and tranny are out and you starter is hanging in the air.
There should be other wires going from the positive battery terminal to the car. The car doesn't get it's power from the thick starter cable. |
ruddyboys |
Aug 6 2004, 12:41 PM
Engine and trans are out. Figured I would have power to the rest of the car if I connected the battery. The wire that goes to the starter is doconnected from the starter and I covered it as to not ground it out. I need a couple of parts before putting the engine in, so I wanted to check the directional signals that I have problems with.
McMark |
Aug 6 2004, 12:48 PM
It should work. How long has your battery been sitting?
ruddyboys |
Aug 6 2004, 04:32 PM
Its only been sitting out of the for about 2 weeks. I will check the connections again tomorrow. I must have pullled a wire while I dropped the engine.
McMark |
Aug 6 2004, 07:14 PM
Check that the battery is not dead as well. If it was going bad, two weeks without a boost will kill it.
Lo-Fi Version | Time is now: 23rd May 2024 - 09:16 AM |
