| patssle |
Nov 15 2011, 05:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I have access to a complete front suspension off a 1974 911. I read I can just remove the hubs, calipers, and struts and use those with the existing 914 parts. Is there any noticeable difference to just remove the entire thing and transplant it, or do those 3 parts really cover the reasons to do the conversion (brakes, 5 lug).
It's a 99% street car, /4 at the moment, /6 3.0L in the future. Thanks. |
| SLITS |
Nov 15 2011, 06:14 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Buy the whole thing and bolt it in. All you are getting is larger torsion bars and the valving on the shocks matches them. Remove the rack that comes with it as the input shaft is longer / shorter than the 914 (don't remember which) and just use the 914 rack.
or You can just use the strut assemblies and mate them to the 914 "A" arms as long as the ball joints are the same style on your 914. |
| patssle |
Nov 15 2011, 09:32 PM
Is there any reason the ball joints would be different? '76 914. And if they are, is that an easy thing to overcome?
| jmill |
Nov 15 2011, 09:38 PM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
I know the 75 and later 911 are the same.
Just checked Pelican. 74-89 is the same. |
Lo-Fi Version | Time is now: 6th March 2026 - 10:27 PM |
