Clutch Condition, To Replace or Not Replace? |
jr91472 |
Aug 11 2004, 09:38 AM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
While in the mist of various other projects, I now have easy access to my clutch. The clutch is fairly new ~11k miles, should I replace now or not?
I have not yet removed the pressure plate, but when I do what wear signs should I look for to help me decide? Is there a minimum thickness on the clutch disk that I can measure? Would rather not spend the money on a new clutch right now if I don't have to, but I don't want to be pulling the tranny again next month either. thanks JR PS: I am a new member and let me just say this club rocks. Thanks to all the members who have already answer multiple questions for me. (IMG:style_emoticons/default/beer.gif) |
Joseph Mills |
Aug 11 2004, 10:46 AM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
If you don't have a manual, obtain one. If everything is "normal", you should not need a new clutch disk with only 11k on the new one. But since you have easy access, I would remove it just for a visual inspection. If this "new" clutch was installed by the PO, you can confirm it's condition (as well as the pressure plate & flywheel). If either your engine main seal, or your tranny seal is leaking, this would be a good time to replace them also.
It's easy to remove the pressure plate, but follow your manual's instructions and remember to torque down to specs. |
Lo-Fi Version | Time is now: 23rd May 2024 - 07:04 AM |
