silverbullet75 |
I reject your reality and substitute my own! ![]() Group: Members Posts: 18 Joined: 3-December 11 From: Las Vegas, NV Member No.: 13,848 Region Association: Southwest Region ![]() |
Thinking about doing an older SBC, carbbed. Those who have this setup, do you pass smog?
Thanks, JIM |
BMITCHELL |
Member ![]() ![]() Group: Members Posts: 328 Joined: 28-February 05 From: Moorpark, CA Member No.: 3,681 ![]() |
75 and older in CA don't need smog. I guess Neveda is not the same.
914GT |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,101 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region ![]() |
Mine easily meets Arizona HC/CO emissions limits (400ppm/5%) as long as I don't have to wait in a long line or let it idle long. Otherwise the carburetor gets too hot due to lack of airflow in the engine compartment and excess gas spills into the intake. Last week mine passed with 207 ppm HC and 1.18% CO.
silverbullet75 |
silverbullet75 |
Mine easily meets Arizona HC/CO emissions limits (400ppm/5%) as long as I don't have to wait in a long line or let it idle long. Otherwise the carburetor gets too hot due to lack of airflow in the engine compartment and excess gas spills into the intake. Last week mine passed with 207 ppm HC and 1.18% CO. Ok, that helps... gives me optimism. Thank you! |
matthepcat |
Meat Popsicle ![]() ![]() ![]() Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California ![]() |
My conversion saw the referee in CA back when the smog year was 67 or somthing like that.
If done correct, with a correct air cleaner, Cat, EGR and smog legal Holley carb, you can pass. It from that point on is smogged as a Camaro or similar vehicle of that year. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,257 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
75 and older in CA don't need smog. I guess Neveda is not the same. I WISH!67 is the current year/cut-off. I thought Nevada just switched to a 30 year rolling exemption? (IMG:style_emoticons/default/idea.gif) |
silverbullet75 |
My conversion saw the referee in CA back when the smog year was 67 or somthing like that. If done correct, with a correct air cleaner, Cat, EGR and smog legal Holley carb, you can pass. It from that point on is smogged as a Camaro or similar vehicle of that year. Thank you! Note: I just changed the title of this thread to add Stock 4cyls. with aftermarket carbs. Have any of you been able to get a 914-4 with carbs to pass smog? |
silverbullet75 |
75 and older in CA don't need smog. I guess Neveda is not the same. I WISH!67 is the current year/cut-off. I thought Nevada just switched to a 30 year rolling exemption? (IMG:style_emoticons/default/idea.gif) That would be nice... Here are the current rules (if interested). It's even more complicated than I lead on... The 67 year is only if you have registered as a classic vehicle, and plan to only drive 5000 miles a year. http://www.dmvnv.com/emission.htm#Fail |
SirAndy |
That would be nice... Here are the current rules (if interested). It's even more complicated than I lead on... The 67 year is only if you have registered as a classic vehicle, and plan to only drive 5000 miles a year. http://www.dmvnv.com/emission.htm#Fail That website might be out of date. I'm pretty sure i heard that NV just recently implemented a 30 year cutoff for classic vehicles. Or maybe i just had a few too many (IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/biggrin.gif) |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
It could be done with carbs...if they are basing the numbers on the year of the car, and a V8 motor...you can get a 70,s v8 to pass.
If you need to meet the standards of today...forget it. Rich |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
That would be nice... Here are the current rules (if interested). It's even more complicated than I lead on... The 67 year is only if you have registered as a classic vehicle, and plan to only drive 5000 miles a year. http://www.dmvnv.com/emission.htm#Fail That website might be out of date. I'm pretty sure i heard that NV just recently implemented a 30 year cutoff for classic vehicles. Or maybe i just had a few too many (IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/biggrin.gif) Most of NV is exempt, but Reno and Vegas still have some restrictions. The loophole is to get it registered as a classic vehicle. Then you are exempt. That is a recent implementation, at least here in Reno. Check into it for Vegas. |
silverbullet75 |
That would be nice... Here are the current rules (if interested). It's even more complicated than I lead on... The 67 year is only if you have registered as a classic vehicle, and plan to only drive 5000 miles a year. http://www.dmvnv.com/emission.htm#Fail That website might be out of date. I'm pretty sure i heard that NV just recently implemented a 30 year cutoff for classic vehicles. Or maybe i just had a few too many (IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/biggrin.gif) Most of NV is exempt, but Reno and Vegas still have some restrictions. The loophole is to get it registered as a classic vehicle. Then you are exempt. That is a recent implementation, at least here in Reno. Check into it for Vegas. Same for Vegas... but you can't drive more than 5k miles a year. |
914GT |
The Nevada exemption looks better then here in Arizona metro areas. I can get classic registration and emissions exemption here, but the catch is I have to get collector car insurance. Doing that means no driving the car to work, even as a backup vehicle and no running errands. I could drive it to work, but if I was in an accident I could be denied a claim. If Arizona just had the 5k mile limit and keep my existing insurance coverage I'd jump at that.
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,757 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
Call around. Different classic car insurance companies have different rules. Some allow trips to work once a week or are willing to negotiate a rate that allows occational trips to work. Everything is negotiable.
Zach |
Lo-Fi Version | Time is now: 12th July 2025 - 11:51 AM |
