Jaymann |
Member ![]() ![]() Group: Members Posts: 140 Joined: 18-August 09 From: Drexel hill pa Member No.: 10,692 Region Association: None ![]() |
I have a small oil leak,It is coming from the oil return tubes.How involved is it to change them out??Are there any parts kits for this???Any help is appriciated.Thanks and Merry Christmass Jaymann from PA
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,831 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
This is a 6 right? There's two options, pull the engine and pull the cam towers, or install the collapsible oil return tubes.
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,964 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Jayson - I think you mean pushrod tubes. Unless your 4 has overhead cams.
luskesq |
Member ![]() ![]() Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California ![]() |
It would be helpful to know what kind of engine you have, a six or a 4. Depending, it could have either push rod tubes or oil return tubes. In this case, size makes a difference.
Keith |
Jaymann |
This car is a 75 and has a bone stock 4 cyl 1.8L motor.Jaymann
luskesq |
Then Mepstein is correct, push rod tubes. Replacement is fairly simple and inexpensive. You need two seals per tube (large & small). Go to the Pelican site under Technical Articles and they have a fairly decent discussion on how to do it. If you search this site I'm sure you'll find further comment.
Have fun and good luck. Keith |
Lo-Fi Version | Time is now: 12th July 2025 - 11:39 AM |
