exhaust options, other stuff... |
Schnell944 |
Apr 30 2003, 03:52 PM
Member Group: Members Posts: 121 Joined: 4-January 03 Member No.: 86 |
I'm finally getting my '72 914 back from the shop tomorrow.....got a side shift tranny done and injection work. the exhaust is shot....what would be a good replacement? i wouldn't mind something a little loud since its jsut going to be an autocrosser. I like the dual outlet design of a manta i saw and also like the performance stuff from Bursch. what are your experiences. also, is it very hard to replace this system yourself? thanks!
Dave Cawdrey |
Apr 30 2003, 04:07 PM
Dumbo going poop, Daddy :) Group: Members Posts: 818 Joined: 22-January 03 From: Seattle, WA USA Member No.: 182 |
Might want to upgrade your exchangers to stainless.
Low and behold a nice set is for sale. Check it out here: SOLD! BTW, your car doesn't need to be a 2L. They will work on any motor. You just have to buy a 2L muffler and hanger. |
Schnell944 |
Apr 30 2003, 04:12 PM
why would i want a set of SS exchangers as opposed to stock? what are the benefits. any info is appreciated. thanks.
Dave Cawdrey |
Apr 30 2003, 04:16 PM
QUOTE(Schnell944 @ Apr 30 2003, 02:12 PM) why would i want a set of SS exchangers as opposed to stock? what are the benefits. any info is appreciated. thanks. They will last longer. Not rust out. I'll let Brad take over... He can list more benefits. He is SSI (IMG:style_emoticons/default/wink.gif) |
Brad Roberts |
Apr 30 2003, 04:19 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
The Bursch setup with SSI's is the hot ticket unless you want to pop for a NO heat header system. They run about 450$ complete with a muffler from a guy in Nevada.
This setup runs me about 580$ after ceramic coating. B |
Brad Roberts |
Apr 30 2003, 04:23 PM
This system uses stub tubes.. which makes it easier to install.
B |
Mueller |
Apr 30 2003, 04:24 PM
The SSI's are lighter by approx. 8lbs which is important to some.
Brad Roberts |
Apr 30 2003, 04:27 PM
Lighter than the stock 2.0 heat exchangers, but will yield faster warm up times and outlast the car as far as corrosion goes.
Ask your mechanic abou SSI's for 914's. He wont disagree. B |
cha914 |
Apr 30 2003, 04:30 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
Brad,
Is that the triad setup or the euro race? I think that is the seup I have, but can't remember for sure... also, I need to get mine coated, do you use jet hot or someone else? Tony |
Qarl |
Apr 30 2003, 04:41 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Thanks Brad for the nice avatar.
I can get my porno at work without surfing the porno sites. Regards, Karl |
Brad Roberts |
Apr 30 2003, 04:54 PM
Tony,
The header is from European Racing Headers...not European Racing. BIG difference. One company pushes Type 4 parts and the other sells headers. I use a guy in Arlington Texas. Jet hot spends NO time properly prepping the pieces. My guy blasts them..acid washes and uses a vibratory polisher to polish the pieces. He also uses much much better coatings than Jet Hot uses. My guy does parts for airplanes which requires a certification. His name is Mike Tomlin and he runs Performance coatings. B |
ChrisReale |
Apr 30 2003, 05:00 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
Brad, what type of muffler can/do you run with those headers? Where can one find them?
Brad Roberts |
Apr 30 2003, 05:06 PM
The guy who sells us the headers sells a complete bolt on kit with his header. The pipe even exits out the stock location. He uses a typical V8 truck turbo muffler. I think the muffler is 125$ of the price and bolts directly to the header flange.
I'll see if I have a pic. B |
brant |
Apr 30 2003, 05:33 PM
914 Wizard Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Brad,
do you think mike thomlin would be interested in picking up new clients.. I haven't yet bought headers...(I'm waiting for the SSI-914/6 to come out).. but I definitely want to coat them when I do get them. brant |
Britain Smith |
Apr 30 2003, 06:14 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Brad,
Do you have a picture of that system installed on a car? Also, can you get the SS stub tubes seperately? -Britain |
Mark Henry |
Apr 30 2003, 06:30 PM
I was flicking past TNN last Sunday and they were installing a custom exhaust. It had a funny 'y' wishbone deal, so i had to watch.
They were installing a SS gate, it was solinoid driven, with a flick of a switch bamm total open exhaust pipe. Flip it again, back on the muffler. Kinda cool! |
cha914 |
Apr 30 2003, 06:56 PM
Brad,
Since i am in Texas, I would much rather use your man to get mine coated...to you have a phone number for him...I will probably get this done within the next month... thanks for the tip, Tony edit: Sweet...I just checked my header and it is the same as above and I got the stinger attachment along with the turbo muffler you describe...and all for 300 (IMG:style_emoticons/default/tongue.gif)...gotta love buying stuff used. |
gklinger |
May 1 2003, 11:57 AM
doh! Group: Members Posts: 316 Joined: 14-January 03 From: Tempe, AZ Member No.: 146 Region Association: Southwest Region |
QUOTE(Brad Roberts @ Apr 30 2003, 03:19 PM) The Bursch setup with SSI's is the hot ticket unless you want to pop for a NO heat header system. They run about 450$ complete with a muffler from a guy in Nevada. This setup runs me about 580$ after ceramic coating. B Hey Brad, Any clearance issues with this setup? Will it accomodate the tuna can sump? Looks nice; since I'm in Phoenix, needing heat isn't an issue, so I'm looking to ditch my nasty looking exchangers for something like this. Do you have a pic of it installed, with or without the street muffler? |
Brad Roberts |
May 1 2003, 12:04 PM
No clearance issues with this setup. All of our cars run the tuna can or the deep sump.
I consider this the middle of the road header. Foleys header being on top and the KH header on bottom. They are priced this way also. I found it humorous that Grassroots didnt test this header back last year on their 2.0 B |
campbellcj |
May 1 2003, 03:24 PM
I can't Re Member Group: Members Posts: 4,550 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
QUOTE(Brad Roberts @ Apr 30 2003, 03:54 PM) Jet hot spends NO time properly prepping the pieces. My guy blasts them..acid washes and uses a vibratory polisher to polish the pieces. He also uses much much better coatings than Jet Hot uses. My guy does parts for airplanes which requires a certification. Hmmm...that's sure not what the JetHot literature says. In fact they specifically talk about the degreasing and stripping process and show pics. They also now do two different coatings with varying heat-resistance properties. |
Lo-Fi Version | Time is now: 11th June 2024 - 06:01 PM |
