| tornik550 |
Dec 29 2011, 08:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
As the title says- is it ok to break in an engine in cold weather? I am getting close to having my rebuild ready for break-in. It is about 30 degrees outside. If ok, what weight break in oil should I use?
| reharvey |
Dec 29 2011, 08:13 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
As the title says- is it ok to break in an engine in cold weather? I am getting close to having my rebuild ready for break-in. It is about 30 degrees outside. If ok, what weight break in oil should I use? Yeah - Who has had experience with this situation. I'm about to do the same thing here in N. E. Ohio. I can warm the garage up before opening the door to start it up. Anyone else done this? |
| Series9 |
Dec 29 2011, 09:19 PM
Lesbians taste like chicken. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,453 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
I would bet that 60% of all Porsches have been broken in during winter weather conditions. Seriously, consider the source.
If you're talking about the first start, I would try to warm up the oil. Otherwise, just drive the car. Once it's running and warmed up, the engine doesn't know it's winter. |
| aircooledtechguy |
Jan 1 2012, 10:40 PM
The Aircooledtech Guy ![]() ![]() ![]() Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
For the initial 25-30 minute break-in run, I would first recommend just letting the motor be either warmed first by being in a heated garage OR by putting a space heater near it for an hour or so. This is just so the oil isn't like engine honey. At 2500-3K RPMs it'll heat-up very quickly anyway.
| Krieger |
Jan 2 2012, 11:31 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,855 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
I know my halogen shop light puts out a ton of heat. Jack up the car if you need to and stick a light underneath it for an hour.
| 6freak |
Jan 2 2012, 10:05 PM
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
As the title says- is it ok to break in an engine in cold weather? I am getting close to having my rebuild ready for break-in. It is about 30 degrees outside. If ok, what weight break in oil should I use? I dont know much.. but i do know i would put a block heater on it 24hrs before i turned the key.... ..5W30...JMO...good luck MikeC (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 30th April 2026 - 05:30 PM |
