Full Version: Is it ok to break in an engine in cold weather?
tornik550
As the title says- is it ok to break in an engine in cold weather? I am getting close to having my rebuild ready for break-in. It is about 30 degrees outside. If ok, what weight break in oil should I use?
reharvey
QUOTE(tornik550 @ Dec 29 2011, 09:02 PM) *
Yeah - Who has had experience with this situation. I'm about to do the same thing here in N. E. Ohio. I can warm the garage up before opening the door to start it up. Anyone else done this?
Series9
I would bet that 60% of all Porsches have been broken in during winter weather conditions. Seriously, consider the source.
If you're talking about the first start, I would try to warm up the oil. Otherwise, just drive the car. Once it's running and warmed up, the engine doesn't know it's winter.
aircooledtechguy
For the initial 25-30 minute break-in run, I would first recommend just letting the motor be either warmed first by being in a heated garage OR by putting a space heater near it for an hour or so. This is just so the oil isn't like engine honey. At 2500-3K RPMs it'll heat-up very quickly anyway.
Krieger
I know my halogen shop light puts out a ton of heat. Jack up the car if you need to and stick a light underneath it for an hour.
6freak
QUOTE(tornik550 @ Dec 29 2011, 06:02 PM) *
I dont know much.. but i do know i would put a block heater on it 24hrs before i turned the key.... ..5W30...JMO...good luck
