Replaced fresh air blower- only have middle speed, can't figure out why there is no low or high working. |
DRPHIL914 |
Jan 5 2012, 11:01 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i have checked the wires, connections etc. the slider contacts have been cleaned and lubed. they contact in all positions but i get one speed to work , #2, middle. any ideas on what , where, how to test? thanks for the help phil |
billh1963 |
Jan 5 2012, 12:09 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
(IMG:style_emoticons/default/confused24.gif) i have checked the wires, connections etc. the slider contacts have been cleaned and lubed. they contact in all positions but i get one speed to work , #2, middle. any ideas on what , where, how to test? thanks for the help phil More cold weather is coming...better get it figured out soon! (IMG:style_emoticons/default/biggrin.gif) |
DRPHIL914 |
Jan 5 2012, 12:16 PM
(IMG:style_emoticons/default/confused24.gif) i have checked the wires, connections etc. the slider contacts have been cleaned and lubed. they contact in all positions but i get one speed to work , #2, middle. any ideas on what , where, how to test? thanks for the help phil More cold weather is coming...better get it figured out soon! (IMG:style_emoticons/default/biggrin.gif) well, heat works fine - this is the fresh air blower - the old one did not work at all the fan was shot, and it did not close so there was always cold air leaking thru when i did not want it - so at least i can de-fog the windows. and i drove the car yesterday and today- toasty warm! Glad i got those Stainless heat exchangers and replaced the window, targa, and door seals - much less draft!! But i know later on i will want the high speed to work , - by the way- how is your's running? had the "pickle" been delivered yet? pw |
McMark |
Jan 5 2012, 07:39 PM
Most likely it's the switch in the dash. The motors get stuck with leaves or corroded bearings. Then when switched on the connections get hot and the plastic melts and the switch doesn't make contact anymore.
Lo-Fi Version | Time is now: 9th June 2024 - 06:04 AM |
