Trans question about syncros |
Harpo |
Jan 5 2012, 04:12 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Here is a newby question for you. Is there a sycronizer for every gear 1-5 & Reverse? Are they all the same?
Thanks DAve |
dadaDaveed |
Jan 5 2012, 04:18 PM
Member Group: Members Posts: 111 Joined: 19-February 09 From: San Antonio, TX Member No.: 10,071 Region Association: Southwest Region |
2-5 are the same
1st is different Reverse has no synchro |
pilothyer |
Jan 6 2012, 01:34 AM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Here is a newby question for you. Is there a sycronizer for every gear 1-5 & Reverse? Are they all the same? Thanks DAve Dave........If I am not badly mistaken, the synchronizing rings are the same for all the gears.......of course the hub is different for first gear..........Jerry |
bulitt |
Jan 6 2012, 05:44 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
I don't know, But IMHO if you rename your thread to "Transmission Question" or something closer to topic, and place it in the Garage Forum the experts will answer you directly. Or just PM Dr.Evil.
Harpo |
Jan 6 2012, 06:45 PM
Of course your correct.
If the moderators can move this to the garage that would be much appreciated David |
Richard Casto |
Jan 7 2012, 01:18 AM
Blue Sky Motorsports, LLC Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
Here is a newby question for you. Is there a sycronizer for every gear 1-5 & Reverse? Are they all the same? Thanks DAve Dave........If I am not badly mistaken, the synchronizing rings are the same for all the gears.......of course the hub is different for first gear..........Jerry For the 914... * Rings the same * Hubs 1st unique, 2nd-5th the same * 1st has it's own brake band, anchor/stop block setup that is slightly different than what is used on 2nd-5th. * 1st can be converted to use the same parts as 2nd-5th. * No synchro on reverse. Richard |
Lo-Fi Version | Time is now: 23rd May 2024 - 06:22 AM |
