Gas Tank, Fuel Lines |
doit2xs |
Jan 5 2012, 06:48 PM
Newbie Group: Members Posts: 20 Joined: 15-February 06 From: Mascotte, Florida Member No.: 5,588 Region Association: None |
Hi, anybody know on the gas tank when using carbs, do you block off the 5/16" line that has the baffle and use the 3/8" line that goes straight through? Do I get a cap to block it off, or just use a piece of fuel line and a bolt?
Thanks, Don |
SirAndy |
Jan 5 2012, 06:56 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Hi, anybody know on the gas tank when using carbs, do you block off the 5/16" line that has the baffle and use the 3/8" line that goes straight through? Do I get a cap to block it off, or just use a piece of fuel line and a bolt? Thanks, Don The one with the screen is the suction outlet for the pump. You can block off the return line but it is actually better if you use it, even with carbs. Keeps the fuel cooler. (IMG:style_emoticons/default/popcorn[1].gif) |
mrbubblehead |
Jan 5 2012, 07:09 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i used these http://www.vwparts.net/CB3288.html then cap off the non screened port (return port)
doit2xs |
Jan 5 2012, 08:00 PM
Hi, screened port? I did not see a screen? Did you get cap at parts store? |
ChrisFoley |
Jan 5 2012, 08:18 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Hi, anybody know on the gas tank when using carbs, do you block off the 5/16" line that has the baffle and use the 3/8" line that goes straight through? Do I get a cap to block it off, or just use a piece of fuel line and a bolt? Thanks, Don The smaller tube isn't really baffled, but is necked down to a small opening at the top. A short piece of 5/16" fuel hose, a long bolt with the threads cut off and two hose clamps is a good cap to block it off. If you remove the 3/8 line there is a tube shaped screen inside the tank fitting. Its a good idea to inspect it and get a replacement if its clogged or damaged. |
mrbubblehead |
Jan 5 2012, 08:54 PM
Hi, screened port? I did not see a screen? Did you get cap at parts store? if you look inside your fuel tank with a flashlight you will see a screen/filter in there. thats the one you will use for your carbs. the other one can be capped off. i get my fittings from summit. except for the fuel tank fittings because summit doesnt carry them. this is a -6 cap for the tank fitting. http://www.summitracing.com/parts/AER-FBM3740/ for 15 dollars worth of fittings, i think its alot safer than a bolt and hose clamp. |
doit2xs |
Jan 5 2012, 10:48 PM
Hi, screened port? I did not see a screen? Did you get cap at parts store? if you look inside your fuel tank with a flashlight you will see a screen/filter in there. thats the one you will use for your carbs. the other one can be capped off. i get my fittings from summit. except for the fuel tank fittings because summit doesnt carry them. this is a -6 cap for the tank fitting. http://www.summitracing.com/parts/AER-FBM3740/ for 15 dollars worth of fittings, i think its alot safer than a bolt and hose clamp. I used a flashlight and one port has a metal plate with a hole in it, the 5/16" one. And the other is wide open the 3/8" one, and you can see out the filler. But no screen. Do you know where I can get the screen? Thanks |
mrbubblehead |
Jan 5 2012, 10:52 PM
MoveQik |
Jan 5 2012, 11:42 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
See Don....what did I tell you. Tons of good info. (IMG:style_emoticons/default/biggrin.gif)
rick 918-S |
Jan 6 2012, 08:42 AM
Hey nice rack! -Celette Group: Members Posts: 20,493 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Hi, screened port? I did not see a screen? Did you get cap at parts store? if you look inside your fuel tank with a flashlight you will see a screen/filter in there. thats the one you will use for your carbs. the other one can be capped off. i get my fittings from summit. except for the fuel tank fittings because summit doesnt carry them. this is a -6 cap for the tank fitting. http://www.summitracing.com/parts/AER-FBM3740/ for 15 dollars worth of fittings, i think its alot safer than a bolt and hose clamp. I used a flashlight and one port has a metal plate with a hole in it, the 5/16" one. And the other is wide open the 3/8" one, and you can see out the filler. But no screen. Do you know where I can get the screen? Thanks Several places sell the screen. Check out the member vendor section here on 914World. http://www.914world.com/bbs2/index.php?showforum=4 If you haven't replaced the plastic line in the tunnel you may want to check out Chris Foley's site. You should consider replacing these lines. They are starting to age out and we have had several of our members loose their cars to fires. http://www.tangerineracing.com/stainlessFuelLines.htm He has a nice stainless steel line kit and also sells the filter screen. And if I didn't say it before.... (IMG:style_emoticons/default/welcome.png) |
cwpeden |
Jan 6 2012, 08:48 AM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
Gas tank screen. Old vs. New.
I have FI, but the old one would actually stop the flow of gas. Besides it is the gasket for the fitting, aluminum crush ring on end. |
ww914 |
Jan 6 2012, 09:02 AM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
Here is a great example of why this forum is so important. I have my engine out and didn't even think about replacing fuel lines until I read this thread. Thanks guys, I love ya.
Lo-Fi Version | Time is now: 10th June 2024 - 01:24 AM |
