Qarl |
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None ![]() ![]() |
My race shop guy is helping me put together my driveline for my six conversion.
He would like me to use '72/'73 axles for the rear, which will necessitate changing the output flanges for the tranny, and the stub axles as well. He says the '72/'73 axles are different than the '71 and earlier axles. However, I can't seem to find differentiation from any of the parts houses. Are the '72/'73 STUB axles different than other early (i.e.. 69 to 71) stub axles or can I use '70 stub axles to mate to the '72/'73 axles? Also, will these stub axles fit into a 914 hub that is drilled for five bolts, or do I need to find '72/73 hubs as well (i.e., is there a spline difference)? What about the the output flanges for the tranny? He says I need to find the 901 output flanges from a 911 from the same year as the axles. Something about length differences. Brad, you're a guru in this area? What do I have to locate? |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Nothing.
Shoot me 400$ and I will send you everything but the axles you need. I stock this stuff and buy it every time I see it at a swap meet. I can get you the axle part number on Monday that I use. NO spacers needed. I have the early hubs/stubs and drive flanges for the 901. They are crusty and old, but I will clean them up for you. The control arm drive flanges slide right into a 914 wheel bearing. B |
Qarl |
Brad, thanks for the reply.
I still need clarification about the differences between '72/'73 and the early hub/axle/stub axle? Thanks, Karl |
Brad Roberts |
From what I have gathered...
All of the CV/axle setup is 4 bolt 2 pin large face like a 930 CV. The 911 stub axles will not go into a 914 drive flange redrilled. They will go into a 9146 drive flange and a ealry 911 drive flange (5 lug) There is a slight difference I have seen between the pieces for the transmission (diff flanges 4 bolt 2 pin) One output flange was approx. 3mm wider than another that I had. I just made sure I had a pair that matched and bolted them in with new axles. Ask him why you need that specific version. B |
Lo-Fi Version | Time is now: 6th July 2025 - 10:28 AM |
