H4 headlights, which bulbs and how much wattage? |
rwilner |
Feb 22 2012, 10:33 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
I replaced the tungsten sealed-beams with the Hella H4s that take bulbs. The bulbs that came with the lenses aren't too impressive.
What are the best bulbs (and wattage) people run with these lenses using stock wiring and relays? |
Tom_T |
Feb 22 2012, 12:15 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Best to get the HP headlight relay kit & upgrade to 80/100w bulbs.
55/65w is the best you can do with stock wiring & relays, so the $25+/- spent for the relay kit is worth it. I did it on our 88 Westy Vanagon & it made a huge difference - wished I'd done it 24 years ago when new! (IMG:style_emoticons/default/blink.gif) |
larryM |
Feb 22 2012, 02:04 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
agreed - got em on my sixer for many yrs
- they will turn night into day as the ads say you can't run that wattage thru the stock headlite switch, so you must get the relays concours judges don't like them tho - "non-oem" as it were Best to get the HP headlight relay kit & upgrade to 80/100w bulbs. so the $25+/- spent for the relay kit is worth it. I did it on our 88 Westy Vanagon & it made a huge difference - wished I'd done it 24 years ago when new! (IMG:style_emoticons/default/blink.gif) |
oldschool |
Feb 22 2012, 02:06 PM
Advanced Member Group: Members Posts: 3,362 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
Are we talking the same set up that people do on the early 911?
jsayre914 |
Feb 22 2012, 02:14 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I replaced the tungsten sealed-beams with the Hella H4s that take bulbs. The bulbs that came with the lenses aren't too impressive. What are the best bulbs (and wattage) people run with these lenses using stock wiring and relays? If you want impressive, you need to get an HID kit, it fits into the H4 housing, they are cheap, and they use the stock wiring. I keep them on all the time day and night. I would never go back (IMG:style_emoticons/default/aktion035.gif) Attached image(s) |
rwilner |
Feb 22 2012, 02:24 PM
oldschool |
Feb 22 2012, 02:29 PM
I replaced the tungsten sealed-beams with the Hella H4s that take bulbs. The bulbs that came with the lenses aren't too impressive. What are the best bulbs (and wattage) people run with these lenses using stock wiring and relays? If you want impressive, you need to get an HID kit, it fits into the H4 housing, they are cheap, and they use the stock wiring. I keep them on all the time day and night. I would never go back (IMG:style_emoticons/default/aktion035.gif) $.....buy? |
Krieger |
Feb 22 2012, 02:46 PM
Advanced Member Group: Members Posts: 4,727 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Who has the HID kits?
RickS |
Feb 22 2012, 04:47 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
"If you want impressive, you need to get an HID kit, it fits into the H4 housing, they are cheap, and they use the stock wiring. I keep them on all the time day and night. I would never go back"
Yeah, but do you get a true low beam AND high beam? I got a kit for my Audi a few years back and it said it included high beam but it was marginally better at best. What about blinding others, did you point your lights down or do you blind people and say 'tough luck'. Is there some kind of beam cut-off for non-HID engineered headlights? |
eric9144 |
Feb 22 2012, 05:22 PM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
RickS |
Feb 23 2012, 12:45 AM
Reading on the pelican site, it appears you will only get low beam...
http://www.danielsternlighting.com/tech/bu...onversions.html Think I will go with 85/100 h4 bulbs and relays. Everything I read about HID in a non-HID lamp is bad news. |
rwilner |
Feb 23 2012, 09:58 AM
Reading on the pelican site, it appears you will only get low beam... They sell a dual-filament kit that gives you both high and low beam. This will retrofit into H4 lenses, which are purchased separately from the kit. The lens/HID package is around $300. QUOTE Think I will go with 85/100 h4 bulbs and relays. me too. do you have a relay selected and a source? is a kit available? |
jcd914 |
Feb 23 2012, 10:26 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Reading on the pelican site, it appears you will only get low beam... http://www.danielsternlighting.com/tech/bu...onversions.html Think I will go with 85/100 h4 bulbs and relays. Everything I read about HID in a non-HID lamp is bad news. (IMG:style_emoticons/default/agree.gif) Too many people out there "upgrade" lighting without regard to the rest of the people out on the road. Jim |
RickS |
Feb 23 2012, 10:27 AM
Reading on the pelican site, it appears you will only get low beam... They sell a dual-filament kit that gives you both high and low beam. This will retrofit into H4 lenses, which are purchased separately from the kit. The lens/HID package is around $300. QUOTE Think I will go with 85/100 h4 bulbs and relays. me too. do you have a relay selected and a source? is a kit available? I am thinking this can be probably be modified to work: http://www.pelicanparts.com/cgi-bin/smart/...%2D%38%39%29%20 |
mrholland2 |
Feb 23 2012, 11:33 AM
Senior Member Group: Members Posts: 753 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
Reading on the pelican site, it appears you will only get low beam... http://www.danielsternlighting.com/tech/bu...onversions.html Think I will go with 85/100 h4 bulbs and relays. Everything I read about HID in a non-HID lamp is bad news. (IMG:style_emoticons/default/agree.gif) Too many people out there "upgrade" lighting without regard to the rest of the people out on the road. Jim I drive a fairly tall vehicle most of the time (Honda Element) and I am constantly blinded by improperly aimed headlights. It is FAR more about the aiming than the wattage when it comes to blinding your fellow travelers. I also bought blue tinted lamps for the Element. After being blinded, I find that I focus back on the road much more quickly with the blue tint and my eye doctor says that it is common to be able to do that especially with aging (46 year old) eyes. |
Eric_Shea |
Feb 23 2012, 12:12 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE I am googling this but more info please if you have it. I found a relay upgrade kit at busdepot...is this the same thing? It appears Tom did a "hit-n-run" (IMG:style_emoticons/default/biggrin.gif) I'm guessing HP just means high powered? |
TravisNeff |
Feb 23 2012, 12:35 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
They have a pre-fab relay kit here
http://www.rallylights.com/detail.aspx?ID=1247 Obviously you would need ot extend the main power lead, but the rest is plug & play |
RickS |
Feb 23 2012, 01:36 PM
Eric_Shea |
Feb 23 2012, 01:38 PM
These relays are located by the lights?
The Bus Depot stuff is 1/2 the price. I'd be concerned with how it ties in with the stock plugs (blig plastic shielded boxes). All doable though... |
TravisNeff |
Feb 23 2012, 01:52 PM
I think these kits are meant to be near the headlights, as I am sure they were made on front engined/front battery cars.
Lo-Fi Version | Time is now: 8th June 2024 - 04:52 PM |
