Contemplating building a 4-speed transmission |
gms |
Mar 1 2012, 04:21 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
I am contemplating building a 4-speed transmission for the track that I race on most frequently. I know this sounds crazy but I feel I have good reason to do so. Currently once up to speed I only use 3rd and 4th gears (on a 5-speed) which is a diagonal cross plane shift. With a 4-speed I would just shift between 3rd and 4th gear using an S-(25:26)-3rd gear and a Y-(28:23)-4th Gear, this would be an easier straight shift between gears. The largest hurdle is filling in first 1st and 2nd second gears, I have an input shaft with a fixed A-(11:34) but then second gear gets into the unobtainium gear ratios.
I would like to find a B-(14:37) or C-(15:36) 1st gear fixed on the input shaft and then using an M-(22:29) 2nd gear would be feasible. Only problem is that I don’t even know if they ever made a B or C gear on the input shaft. Looking at the list of gear boxes I see that they made several 912 boxes with an E-(17:34) 2nd gear, that would probably work too. The F-(18:34) would just be too easy to stall the engine. I am open to other suggestions except for an input shaft with welded on gear. If you are not familiar with the 4-speed it is the same as the 5-speed with out installing a first gear. So every gear on a 4-speed is one gear lower when compare to a 5-speed. Example: 4-speed 1st gear is in 5-speed’s 2nd gear position And so on… |
Dr Evil |
Mar 1 2012, 04:58 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Probably Brad and I can help. I have a Y gear and an A shaft.
gms |
Mar 1 2012, 05:05 PM
gms |
Mar 1 2012, 05:08 PM
Dr Evil |
Mar 1 2012, 05:14 PM
No B, C shafts stock. The E shaft is rare = $1200 probably. Gonna have to call Carquip and lube up your ass for the payment (IMG:style_emoticons/default/blink.gif)
gms |
Mar 1 2012, 05:19 PM
No B, C shafts stock. The E shaft is rare = $1200 probably. Gonna have to call Carquip and lube up your ass for the payment (IMG:style_emoticons/default/blink.gif) Looks like I am going with the A, thanks for your input Mike |
Lo-Fi Version | Time is now: 8th June 2024 - 06:25 PM |
