70-74 front air dams, Let's see your dam pics |
Mark Henry |
May 5 2003, 12:47 PM
I’ve made an air dam for my 74. It’s a copy of a friend’s, but I added an air intake for when I install my oil cooler. I like it, but I now think it’s a bit short, I may make a new one. I’d like to see as many dam pic’s as I can. Dam-dam-dam!
These pic’s are before I painted it, they just show up better than the black. Attached image(s) |
Mark Henry |
May 5 2003, 12:49 PM
the backside:
Attached image(s) |
Mark Henry |
May 5 2003, 12:53 PM
WTF did I do to the title!!!! (IMG:style_emoticons/default/confused24.gif)
cha914 |
May 5 2003, 01:11 PM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
looks good, is it fiberglass?
Lawrence |
May 5 2003, 01:56 PM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
Mark,
I have no picture to share, but I did fix your topic title for you. -Rusty |
Mark Henry |
May 5 2003, 02:01 PM
Yep,
I took an old busted up plastic dam, fixed/modified it with sheet aluminum, wood, fiberglass bondo and screws, then fibreglassed it front and back. It's quite light, lighter than a stock valance. When I add a cooler I can just pull the plugs as it's sealed against the body. Thanks Rusty for the fix (IMG:style_emoticons/default/beer.gif) |
Mueller |
May 5 2003, 02:23 PM
I only have this picture for now....
It's on my '74 Attached image(s) |
Jeffs9146 |
May 5 2003, 02:25 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I haven't decided if I am going to use this one or not!!
Jeff Attached image(s) |
Jeffs9146 |
May 5 2003, 02:26 PM
Back
Attached image(s) |
Mark Henry |
I'm very sure that Mike's dam is the one I modified.
meursault |
May 5 2003, 03:56 PM
Idjit Savant Group: Members Posts: 290 Joined: 26-February 03 From: San Diego, CA Member No.: 355 |
Jeff has an air dam. The others are limited edition-type spoilers. I think the distinction is that Jeff's front valence replacement "dams" oncoming air by reaching down as low to the ground as possible to try to prevent much airflow underneath the car. The LE spoiler makes no such attempt.
krk |
May 5 2003, 04:50 PM
Senior Member Group: Members Posts: 997 Joined: 27-December 02 From: San Jose Member No.: 22 |
I ran an air dam like Jeff's for a while -- it as a little too low for the average driveway in my neck of the woods. The nice part was, since the lower part is flexible, you can trim it quite easily with a razor knife.
I'm now on a stock front valence kick, and have just installed one on my /6. It means have a spare LE front spoiler that I can change back too when I want a change. kim. |
Aaron Cox |
May 5 2003, 05:01 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
i like your air dam. interesting (small) cutout for an oil cooler
URY914 |
May 5 2003, 07:29 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,038 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Mine is not really a street spoiler but it stated out as a deep limited edition as sold by AIR. I added about 3", the brake ducts and the bottom lip. Under full braking it is about 3/8" above the track. I also tied it into the f/g bumper so it is one piece.
Attached image(s) |
914Timo |
May 6 2003, 06:59 AM
******* Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe |
This is my. First I did FG mold from some aftermarket spoiler. Then I stretched the lower edge couple of cm in the mold and modified the opening for the oil cooler. Then I did this one from the mold.
Attached thumbnail(s) |
Gint |
May 6 2003, 09:39 AM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Timo, if I've never said it before, I'll say it now. That is one VERY nice looking 914.
Jeffs9146 |
May 6 2003, 09:42 AM
I'll second that!!! One sweet ride!! (IMG:style_emoticons/default/pray.gif)
I think I will leave the rubber piece off of my air dam like you did!! Jeff |
seanery |
May 6 2003, 09:43 AM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
me 3.
Is that a fiberglass front bumper? |
914Timo |
May 7 2003, 12:01 AM
That was nice. Thank you VERY much. It is encouraging to get good feedback. (IMG:style_emoticons/default/smile.gif)
Yes, that is FG bumper. The "rubber top" is custom desing. It is smoother than the original rubber. |
rhodyguy |
May 7 2003, 05:26 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
here's yours on the car jeff.
kevin Attached image(s) |
Lo-Fi Version | Time is now: 7th June 2024 - 11:00 PM |
