Where does this wire go?, Center console wiring |
JRust |
Mar 5 2012, 03:09 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I can't remember where this wire goes. It is in the wiring for the center console. It is brown with a screw eye type connector on the end. I am thinking it is just a ground that I attach to the screw. The screw that goes in the mount attaching the center console to the tunnel?
In the picture it is the brown wire wrapping around the shifter? Sorry if the picture isn't a better close up. Actually I am not positive it is brown. That is just what is in my head today (IMG:style_emoticons/default/blink.gif) . Hopefully this is a no brainer for someone (IMG:style_emoticons/default/biggrin.gif) Attached image(s) |
toolguy |
Mar 5 2012, 03:19 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
test it with a meter. . I believe it is the ground lead from each gauge and goes to frame ground. . maybe to one of the shifter bolts. . didn't look long enough to go to one of the console top mount bolts
JRust |
Mar 5 2012, 03:25 PM
Its just right for it to attach to the mount under the gages to the floor. It's what I figured but couldn't remember pulling it off ?
JeffBowlsby |
Mar 5 2012, 04:44 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
It goes under the nut on the screw on the backside of the lower console panel holding the defrost lamp housing. Completes the ground path.
rwilner |
Mar 5 2012, 06:45 PM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
It goes under the nut on the screw on the backside of the lower console panel holding the defrost lamp housing. Completes the ground path. (IMG:style_emoticons/default/agree.gif) |
JRust |
Mar 5 2012, 07:24 PM
It goes under the nut on the screw on the backside of the lower console panel holding the defrost lamp housing. Completes the ground path. (IMG:style_emoticons/default/biggrin.gif) Perfect! I knew some genius would set me right. Thanks Jeff & it's even more fitting that you set me right as it is in my LE (IMG:style_emoticons/default/creamsicle914.jpg) |
Lo-Fi Version | Time is now: 9th June 2024 - 06:31 AM |
