Shifter adjustment and tranni test |
914itis |
Mar 8 2012, 11:26 AM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I have my motor and tranni mounted on the car, my cv's are not. I need to test and adjust the shifter and my tranni, I am thinking to start the car and make the adjustment without moving the car since the cv is off. Are there any disadvantage doing it that way instead of driving the car? Will the results be any different than actually driving it?
Anyone done this before? |
Bartlett 914 |
Mar 8 2012, 02:06 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Waste of time in my opinion. Get it running with the CV's installed.
914itis |
Mar 8 2012, 02:31 PM
Car is not ready to hit the street yet, I figured that I will have to do less adjustment on the streets.
Dr Evil |
Mar 8 2012, 04:37 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
No need to run the engine at all. Just adjust it.
914itis |
Mar 8 2012, 04:40 PM
bigkensteele |
Mar 8 2012, 06:04 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Download and read the 31 page document that is embedding in Dr. E's signature above. It will tell you everything you need to know and then some. (IMG:style_emoticons/default/thumb3d.gif)
rgalla9146 |
Mar 8 2012, 09:03 PM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I have my motor and tranni mounted on the car, my cv's are not. I need to test and adjust the shifter and my tranni, I am thinking to start the car and make the adjustment without moving the car since the cv is off. Are there any disadvantage doing it that way instead of driving the car? Will the results be any different than actually driving it? Anyone done this before? Hi Paul It will be very difficult to adjust the linkage without being able to drive the car. You won't be able to tell which gear you have and you'll have to be in the car and under it at the same time. Put the axles in it and drive it. Use a marker on the splines to know depth and rotation as you adjust. |
Lo-Fi Version | Time is now: 10th June 2024 - 02:42 AM |
