How much is a EA core worth? |
dakotaewing |
Mar 9 2012, 11:18 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
I have a full EA core motor complete with heads, engine tin, alternator, flywheel, clutch and pressure plate - no distributor or injection... Any ideas what it's worth...??? Please accept my apologizes if I need to post this in the classifieds... I can post a pic tomorrow, if needed. I just want to get this out of my garage reasonably quickly. Figured I would post it on CL for a couple hundred, and put some money in my car account...
Just want to make sure I'm close- Thanks! Thom |
wingnut86 |
Mar 10 2012, 10:30 AM
...boola la boo boola boo... Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
Post your pics as a minimum. You'll be ignored otherwise.
Take real compression numbers for each cylinder and post as well. Measure your pressure plate depth if possible to help folks decide whether it needs or can survive another turn down. |
Mikey914 |
Mar 10 2012, 11:14 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Also, 3 or 4 stud heads, will give you an idea if it's a 2.0 or not. Pics help A LOT.
Dave_Darling |
Mar 10 2012, 01:29 PM
EA code would be a 1.7 engine.
Value depends on what is on it, what kind of shape it seems like it's in, and how badly you want it gone. I'll guess at the $150-$500 range. --DD |
larryM |
Mar 10 2012, 03:06 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
that's also a high compression motor - maybe won't run well on currently sold pump gas
basically it's a boat anchor except to somebody who is anal about originality post in The Samba - some sandbuggy guy might want it EA code would be a 1.7 engine. Value depends on what is on it, what kind of shape it seems like it's in, and how badly you want it gone. I'll guess at the $150-$500 range. --DD |
reharvey |
Mar 10 2012, 04:23 PM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
The 1.7 and 1.8 stuff is a hard sell. I've got lots of these parts and they're really not in demand. A 1.7 rebuilable core may be worth $150.
brant |
Mar 10 2012, 04:31 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I've seen 1.7 motors going for 50-ish
I paid 60 for the last one I bought its a few hours work just to get them disassembled if someone needs the case.... the case is worth using for most builds the misc hardware is ok but the internals are really not valuable. |
rhcb914 |
Mar 10 2012, 07:09 PM
member Group: Members Posts: 358 Joined: 3-February 04 From: Boston, MA Member No.: 1,626 |
Last one I had almost had to give away. I think I got $30 for it.
TravisNeff |
Mar 10 2012, 07:48 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
Is your car done yet? (IMG:style_emoticons/default/poke.gif)
larryM |
Mar 10 2012, 10:57 PM
worth more as parts if you have the patience to do that
shipping cost exceeds value as a complete motor crank, heads, distributor, some FI parts if ya can g'tee good, etc - throw away the rest - try the VW bus market via Samba - we 914 guys already have more such stuff sitting around than we want |
TheCabinetmaker |
Mar 11 2012, 08:18 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
dakotaewing |
Mar 12 2012, 10:58 AM
I want thank everyone who replied for their input -
In regard to my car, as Clay has said many times, I don't have one... (IMG:style_emoticons/default/biggrin.gif) For those who would think that this is a classified ad, (IMG:style_emoticons/default/bs.gif) I won't post this item for sale in the classifieds just for you- Pics can be found below, which indicate that the motor has 1.7 /1.8 heads - I don't have the means for a compression test, and all appearances would indicate again, that this is a CORE engine... Attached image(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:31 PM |
