| cap10danny |
Sep 19 2004, 07:25 PM
Newbie ![]() Group: Members Posts: 1 Joined: 14-September 04 From: LHP fl. Member No.: 2,758 |
My 73 has the left front and rear parking light always on, key on or off. Only can get it off by pulling the 5th fuse. Tried replacing the turn signal switch with a new one, but no help. anybody seen this? Maybe the headlight switch?
| AndrewBlyholder |
Sep 20 2004, 02:54 PM
Member ![]() ![]() Group: Members Posts: 112 Joined: 20-September 04 From: Richmond, CA Member No.: 2,791 |
Just so you know, 914's are wired so that if you leave the turn signal on, that turn signal lights on that side stay on after the car is turned off and key removed. I was once told this is a feature required by some European locations where they want the side lights on when you park parallel to the curb. What all this means to you is that it is normal for the turn signals to be hot even with the key off. I'd guess that system is shorted or malfunctioning in some way in your steering column switch assembly.
Andrew Blyholder |
| BMartin914 |
Sep 20 2004, 03:08 PM
||| ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
Funny...
Your left side marker/turn lights won't go off, mine won't come on. Traced down the wiring, checked all of the connections, still can't see a problem. I am expecting a broken wire somewhere. What fun. |
Lo-Fi Version | Time is now: 4th October 2026 - 01:20 PM |
