Can OEM center caps be restored? |
JeffBowlsby |
Mar 17 2012, 07:17 PM
914 Wiring Harnesses Group: Members Posts: 8,536 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I have this dented set...looking for some one to restore them for me. How perfect can they get or will they always be wavy? I think they are stainless steel?
Attached image(s) |
1970 Neun vierzehn |
Mar 17 2012, 09:20 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
Poked them out from the back with a screwdriver handle, eh Jeff? (IMG:style_emoticons/default/poke.gif)
Did that once, so I replaced it long ago. But, I'd bet you would need a very heavy stamping press to get those wrinkles out. Paul |
914_teener |
Mar 17 2012, 09:37 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Poked them out from the back with a screwdriver handle, eh Jeff? (IMG:style_emoticons/default/poke.gif) Did that once, so I replaced it long ago. But, I'd bet you would need a very heavy stamping press to get those wrinkles out. Paul Agree.......but the metal will have to be shrunk first then pressed and then refinished. |
JeffBowlsby |
Mar 17 2012, 09:58 PM
Poked them out from the back with a screwdriver handle, eh Jeff? (IMG:style_emoticons/default/poke.gif) Did that once, so I replaced it long ago. But, I'd bet you would need a very heavy stamping press to get those wrinkles out. Paul Nope not me...I am smarter than that, these came to me that way. |
Mikey914 |
Mar 17 2012, 10:12 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The only way to restore would be a die set, even then they would have to be striped and refinished. You still have the issue of galvanic corrosion. And they at easily deformed. There is a special removal / install tool. I could make some to keep them from being damaged. But that's the only way to keep from damaging these again.
JeffBowlsby |
Mar 17 2012, 10:20 PM
Mark, you think a 2 piece die set that would flatten them in a press would do it? There may be a market for this service.
I think these are polished stainless steel...but have not taken a magnet to them yet, they dont look like chrome to my eye...and no rust. |
Mikey914 |
Mar 18 2012, 12:21 AM
I can make the dies, not sure if they will press completely flat, but worth a try.
I'll start a thread on the removal / tool. The best way to keep from damaging these in the first place. |
sixnotfour |
Mar 18 2012, 02:54 AM
914 Wizard Group: Members Posts: 10,437 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Jeff /Mark , I have the die set and the ones pictured can be pressed and polished like new.
nasty ones take some shrinking , Jeff's are not that bad. |
Bartlett 914 |
Mar 18 2012, 06:45 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I made a simple die set to do this. My arbor press is only 2 ton. It did help but a lot more tonnage will be needed to make them flat. They are good enough if you want to put a sticker on them
rgalla9146 |
Mar 18 2012, 07:07 AM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I made a simple die set to do this. My arbor press is only 2 ton. It did help but a lot more tonnage will be needed to make them flat. They are good enough if you want to put a sticker on them They are definitely stainless and that is a very big plus. It is very workable and can be polished to practically new appearance. A press and die is good but great results are possible without heavy equipment. The right craftsman with a light touch can get great results. Sharp creases on the rim are tough though. |
914_teener |
Mar 18 2012, 09:27 AM
I made a simple die set to do this. My arbor press is only 2 ton. It did help but a lot more tonnage will be needed to make them flat. They are good enough if you want to put a sticker on them They are definitely stainless and that is a very big plus. It is very workable and can be polished to practically new appearance. A press and die is good but great results are possible without heavy equipment. The right craftsman with a light touch can get great results. Sharp creases on the rim are tough though. More tonnage will stretch the metal. Stainless "work hardens" then it is very difficult to work. With stainless less working is better. Shrinking the metal first and then press them with a flat die set with minimal tonnage enough to straighten them. |
Lo-Fi Version | Time is now: 12th June 2024 - 12:42 PM |
