1973_1.7 |
Newbie ![]() Group: Members Posts: 19 Joined: 9-September 09 From: Norway Member No.: 10,784 Region Association: Europe ![]() |
I know i cant use a tailshift engine beam with sideshift transmission, but is it possible the other way? Sideshift engine beam with tailshifte transmission?
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,276 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
I know i cant use a tailshift engine beam with sideshift transmission, but is it possible the other way? Sideshift engine beam with tailshifte transmission? I'm pretty sure the shift-rod won't fit around the engine mount bar ... (IMG:style_emoticons/default/idea.gif) |
1973_1.7 |
The problem is that I have a freshly rebuilt tailshift transmission without the linkage, and the linkage is difficult to source in Norway. I have to get shipped from somewhere abroad, and the shipping will be much cheaper without the engine bar.
So it would be great to know if I can use my engine bar or not, that would save me alot in shipping as they are big and heavy (IMG:style_emoticons/default/smile.gif) |
SirAndy |
The problem is that I have a freshly rebuilt tailshift transmission without the linkage, and the linkage is difficult to source in Norway. I have to get shipped from somewhere abroad, and the shipping will be much cheaper without the engine bar. So it would be great to know if I can use my engine bar or not, that would save me alot in shipping as they are big and heavy (IMG:style_emoticons/default/smile.gif) Do you have a spare sideshifter? You can convert your tailshifter to a sideshifter ... (IMG:style_emoticons/default/idea.gif) |
1973_1.7 |
I have a spare sideshifter, I opened it up and changed the synchro bands but I cant get it to shift properly and I am lacking 4th and 5th gear, so the tailshifter was supposed to be a quick fix until I get the sideshifter opened up and adjusted properly. What needs to be changed to convert the sideshifter?
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Did you get my DVD? It will cover all of this.
To your original question, no. The front mounts on the engine to the bar are totally different. |
Dr Evil |
By the way, it would be pretty easy to make a tail shift mount bar, but not a side shift one.
1973_1.7 |
Hi Dr. evil , I have not received your dvd yet but some times the mail takes a little time.
I also have the engine mounts for a tailshifter, so its just the engine mount bar and the linakge i am missing. But the tailshift linkage does not clear the engine mount bar from a sideshifter? |
Dr Evil |
The mounts from the engine to the tail shift bar are different and wont work on the side shift bar. Honestly, I can not remember if the tail shift linkage will work with a side shift bar as this is not a common conversion. I have seen a side shift linkage with a tail shift bar and that does not work.
Again, if you have all the bits except for the mount bar, the tail shift bar is easy to make. |
Lo-Fi Version | Time is now: 31st July 2025 - 07:56 AM |
