'nother transmission question, output flange endplay |
sgomes |
Oct 2 2004, 03:54 PM
Electric Member Group: Members Posts: 815 Joined: 6-May 04 From: Campbell, CA Member No.: 2,029 |
I just got my transmission back from being thoroughly rebuilt. Looks great! Thanks HPH!
One thing I noticed however is there seems to be a heck of a lot of endplay on one of the output flanges. The one on the passenger side (with the differential access plate) has no measurable endplay. The one on the driver's side moves in and out an amazing 0.025" or so. I measured this with a caliper so the number is not too good. It was so much that I just wanted to get a rough number. Is this ok? To answer your first question, yes I checked the torque on the expansion bolt and it seems fine and had no effect on the endplay. I would wait until Monday to call HPH but this weekend it likely the only time I'm going to get to install this thing before the car show next saturday. Can anyone help? Red Beard? |
Red-Beard |
Oct 2 2004, 04:33 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
That is not normal. Put a screw driver into one of the CV bolt holes to hold the flange in place and re-check the bolt for being torqued.
sgomes |
Oct 2 2004, 06:35 PM
Thanks for the reply. Yeah, I just went a re-checked the torque again. This time I took the bolt all the way out and re-clocked the flange to a different spot. had to do it quickly because the tranny is full of fluid. Anyway, long story short it's no different. I guess it has to go back to HPH (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
They replaced all six bearings so it can't be that. I hope it's just a missing shim or washer or something. (IMG:style_emoticons/default/barf.gif) |
Red-Beard |
Oct 2 2004, 07:04 PM
There aren't any shims or washers there. Well there is a washer under the bolt.
Hmmm. Something wrong with the diff? A month ago I could go look at a million of them...What value did you torque the bolt to? (IMG:style_emoticons/default/idea.gif) |
sgomes |
Oct 2 2004, 08:55 PM
I don't know what they torqued it to but I did 30 ft-lbs.
KenH |
Oct 2 2004, 11:47 PM
Senior Member Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
WELL I JUST CHECKED MY SPARE AND IT HAS ABOUT THAT MUCH END PLAY ON BOTH SIDES. Humm left Caps on.
I believe the one I put in the car has end play. I also looked at a a spare diff. and my feeling is the end play is normal and I would be suprised if it did not have any. There is no Spec in the Porsche books about this. Ken |
ChrisFoley |
Oct 3 2004, 05:47 AM
I am Tangerine Racing Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I think the endplay is normal. My race box was freshly rebuilt by Musante Motorsports and has that much play.
Go ahead and install it. |
sgomes |
Oct 3 2004, 10:57 AM
Thanks for checking you two. That gives me more confidence. So can I get that in writing Chris? (IMG:style_emoticons/default/laugh.gif) What concerns me is that the two sides are different. The passenger side has absolutely no end play but the driver side feels loose! It takes no effort to rattle it back and forth.
bondo |
Oct 4 2004, 04:50 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Hmm, I just checked the three trannies I haven't disassembled yet.. They all had play on both sides.. looks like the concern is not why one side has play, but why the other side doesn't. If you tap it with a hammer can you get it to move back and forth at all? maybe it's just stiffer.
sgomes |
Oct 4 2004, 06:28 PM
(IMG:style_emoticons/default/laugh.gif) The more I look at this thing the more I'm thinking like you! I talked to HPH today and they agreed with you guys that the endplay isn't all that exciting. I'm now becoming concerned as to why the other side is tight! I haven't started to (IMG:style_emoticons/default/smash.gif) it and I don't intend to. I have pulled and pushed on it pretty hard and I think it might have about 0.005" of endplay but I don't think I can measure that well. I'm just about at the point of slapping it in there and moving on.
bondo |
Oct 4 2004, 06:42 PM
I would think it would be fine as long as it wasn't tight. As long as everything turns smoothly and easily, I say put it in and drive. If anything does go wrong you'll hear it long before the rest of us with loud engines would (IMG:style_emoticons/default/smile.gif)
sgomes |
Oct 4 2004, 10:58 PM
QUOTE(bondo @ Oct 4 2004, 04:42 PM) If anything does go wrong you'll hear it long before the rest of us with loud engines would (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/chairfall.gif) Yeah I'm once burned twice shy though. Last time I drove this car the tranny made such an awful noise I had to pull over and flatbed it back to the garage. Several kilo-bucks later here I am! |
Lo-Fi Version | Time is now: 16th June 2024 - 10:44 PM |
