D-jet Fuel Pump question connection, need help |
jsayre914 |
Apr 12 2012, 11:55 AM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
my plastic connector on the D-jet fuel pump is ng
Wich terminal is hot and ground when looking at my picture. I did a search and cannot find a pic. Is my picture correct or backwards??? Attached image(s) |
SLITS |
Apr 12 2012, 01:39 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
It's marked ... marked on the front of the barrel electrical connector.
Your diagram is bassakwards ..... |
JeffBowlsby |
Apr 12 2012, 02:01 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Factory Manual sez....BUT ITS WRONG!!!!
(IMG:style_emoticons/default/sad.gif) Attached image(s) |
jsayre914 |
Apr 12 2012, 02:51 PM
SLITS |
Apr 12 2012, 03:59 PM
Well Jeff & all .... I just looked at 3 pumps and the connections are opposite what the manual says.
I may be old, but I ain't stupid Image of the front of the barrel connector; they are clearly marked opposite. (IMG:http://www.914world.com/bbs2/uploads_offsite/i239.photobucket.com-1696-1334267973.1.jpg) And no BS about this not being a 914 pump (it's a Volvo) but the other two I looked at were 914 pumps ... I'll even post the Bosch OE if necessary. Now, with the connector turned down and you're laying under the car looking up ... I'll buy your connection diagram. |
poorsche914 |
Apr 12 2012, 04:30 PM
T4 Supercharged Group: Members Posts: 3,091 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
(IMG:style_emoticons/default/agree.gif) with SLITS.
I just replaced my old fuel pump so went out and checked. It is marked as shown in the SLITS' photo. (IMG:style_emoticons/default/driving.gif) |
914_teener |
Apr 12 2012, 06:38 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) with SLITS. I just replaced my old fuel pump so went out and checked. It is marked as shown in the SLITS' photo. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/agree.gif) I am with Ron....the Pawn Star. This is not out of a Vulva. Came from my stock 73. Maybe that is a Euro manual Mr. Bowlsby? |
JeffBowlsby |
Apr 12 2012, 10:45 PM
Good catch on the factory manual goof...its wrong...post changed above to inform those who find this thread later...
(IMG:style_emoticons/default/smile.gif) |
Dave_Darling |
Apr 12 2012, 11:51 PM
I was never clear if the picture showed the plug on the wires, or the connector on the pump...
--DD |
SLITS |
Apr 13 2012, 10:35 AM
Good catch on the factory manual goof...its wrong...post changed above to inform those who find this thread later... (IMG:style_emoticons/default/smile.gif) Not so much wrong as no explanation as to the orientation of the pump and where you are looking from. Barrel turned down in mounting position and you laying on your back looking up, the diagram would be correct. The Tech Writers fail to mention this though. |
jsayre914 |
Apr 13 2012, 12:47 PM
looking closer at the tech picture, i noticed it is mounted on the side of the car rather than the firewall. Is that correct? or did different years mount the pump in diff locations?. Mine is mounted low on the firewall with the hoses facing out tward the passenger side, the pic above shows it parallel with the heater tube
(IMG:style_emoticons/default/WTF.gif) |
SLITS |
Apr 13 2012, 12:58 PM
Original mount was to the inner wheelhouse, below engine shelf on body on passenger side (as in the image). There were two rubber isolation mounts it was attached to.
It really doesn't make any difference though. |
JeffBowlsby |
Apr 13 2012, 01:06 PM
More or less a stock FP install here:
Attached image(s) |
JawjaPorsche |
Apr 13 2012, 04:52 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
Thank you Jeff for such an awesome picture of the fuel pump configuration. WTF was the designer thinking? No wonder there was many fires there. Almost impossible to replace the hoses unless you had experience building a ship in a bottle. Plastic fuel lines! Not to mention how close the pump is to the heat tunnel. I am sure the extreme heat there sent many pumps and hoses to a early grave. My first one failed after two years. This is a picture is with engine out too!
I moved my pump 20 years ago and I can replace hoses easier plus monitor potential problems before it becomes a real problem! |
Lo-Fi Version | Time is now: 7th June 2024 - 04:36 PM |
