Gearbox case opinion |
Montreal914 |
Apr 16 2012, 07:59 PM
Senior Member Group: Members Posts: 1,592 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Hello everyone,
I'm currently rebuilding my gearbox, thanks to Dr Evil video, but I'm facing this situation: I have two gearbox: One has a case that is corroded inside (differential area) see picture and I'm questioning it's usage. I believe this case was leaking but I don't have a confirmation. I've put a puddle of brake cleaner fluid and let it sit for a couple of hours last night to see if it was going through the pores but the underside stayed dry. The other one has a main seal that started leaking a few weeks/months after my mechanics had replaced it. Looking at the input shaft's sealing surface, it's not as nice as the shaft from the corroded case one. From what I understand, it's better to keep things together and only replace the wearing parts (bands, dogteeth, sliders). Recommendations (IMG:style_emoticons/default/sad.gif) Thank you, (IMG:style_emoticons/default/smile.gif) |
Dr Evil |
Apr 16 2012, 11:07 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
You can swap shafts as long as you also swap the 2nd gear with it as a set. The corrosion in the box is not a problem if it is not all the way through.
Montreal914 |
Apr 16 2012, 11:46 PM
OK, I understand the second gear issue (we already established the gear matching in a previous discussion). But if I swap the input shaft I don't want to mix the intermediade plate because this will have an influence on the pinion shaft position in relation with the differential, correct?
If I remove the input shaft from the intermediate plate (not sure I remember seeing that in you video) I will want to use the matching bearing races to the bearing. Basically, always match working contact surfaces. Thanks for the help, (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 12th June 2024 - 07:51 PM |
