| Engman |
Oct 7 2004, 12:44 PM
Zoisite ![]() ![]() ![]() Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 |
Well - here is my list of stuff to finish before the FFC04.
Reinstall side marker lights Set idle speed (running 1300rpm at idle) Fix front dash cover Install new door seals Check CV bolts Check Tranny Fluid Decide what parts to take for swap meet Install 914 Club sticker (duh) What has everyone else got left? I know Sean is still working on brakes and sway bars (IMG:style_emoticons/default/laugh.gif) M |
| GaroldShaffer |
Oct 7 2004, 12:54 PM
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,648 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None
Put the Fuchs back on and wash the car (IMG:style_emoticons/default/biggrin.gif)
| ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
change oil & filter
change air filter replace spark plugs ran a can of BG44 through the fuel system install the radar detector install the cellphone antenna and car kit install the bug deflector Rain-X the windows Install 914 Club sticker (duh) |
| jim912928 |
Oct 7 2004, 01:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,487 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
I've got a list!
1. all 4 wheels brake rebuild (done, in the bleeding process but damn bleeder screws (new) leak around the caliper. 2. pedal cluster build (since I'm putting in a new clutch cable and have the console and stuff out..better do this to). 3. new clutch cable 4. hook up all the hoses for the fresh air vents in front 5. change oil 6. maybe hook up the heater control boxes and hoses in the back? 7. shift rod bushings (all of them). Found the cup one in the back didn't even exist! I'm going to be busy! Jim p.s. fixed my hard to open trunk..i tied a piece of bailer twine to the latch and shoved it down inside the front bumper pad... when I need to open it i just pull...hint hint on the new front trunk cable stuff! |
| seanery |
Oct 7 2004, 01:24 PM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
ok, here we go....
1. figure out why dustcaps won't fit front rotors 2. hope that replacement hardware shows up so I can install front calipers 3. install front calipers 4. finish building new hard lines (oops-gotta do this before #3) 5. replace pads in rear calipers & set tolerances (hope they clear the 914-6 rotors back there) 6. install hard lines in rear 7. install rear calipers 8. figure out how to get the damn rear sway bar attached to the balls on the shock mounts 9. fit new valence to front of car 10. uh, now it's scary - check inside of case to see if there is any debris 11. if no debris - replace pistons & cylinders with 96s that are in garage 12. get heads back - damn, why so long? 12. install heads & rest of motor stuff 13. put tin on 14. install motor 15. hope tailshifter isn't trashed 16. install tranny (well-with #14) 17. hope all that goes well and the car works 18. finish Engman fuse panel install 19. add J West Fog flash module 20. paint turn signal block off plates 21. install turn signal block off plates 22. install pedal board 23. install new pedals 24. wash the damn car 25. hope it works well |
| seanery |
Oct 7 2004, 01:26 PM
26. install fuel tank (IMG:style_emoticons/default/headbang.gif)
| Engman |
Oct 7 2004, 01:31 PM
Wow Sean. Do we need to add Thursday prior to the FFC as 'Let's all fix Seans car day' ? I remember last year............
Cant help you this weekend as we have company coming in, but might be able to help you later next week. Let me know if there is any help you need. M |
| Jeroen |
Oct 7 2004, 01:53 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
QUOTE(seanery @ Oct 7 2004, 09:26 PM) 26. install fuel tank (IMG:style_emoticons/default/headbang.gif) Yep, it'll run like crap without it (IMG:style_emoticons/default/biggrin.gif) |
| rick 918-S |
Oct 7 2004, 01:58 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,279 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
Oh Ya, I've got a list!
| jim912928 |
Oct 7 2004, 02:10 PM
man...after seeing all this for once I do feel like I'm overwhelmed! Good luck all of you in worse shape them me! lol
| dakotaewing |
Oct 7 2004, 04:00 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,167 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region
After you guys get everything else dealt with, make sure you take walkie talkies, so when your on the road, you can comunicate from car to car!!!!
-Thom |
| ArtechnikA |
Oct 7 2004, 04:08 PM
the packing list is a separate list, and yes, the FRS/GMRS radios are on it. along with camera, film, cellphones, AAA card - and we're not even in a teener !
| Engman |
Oct 7 2004, 07:01 PM
(IMG:style_emoticons/default/idea.gif) Kinda sounds like the Alien may make a landing at the FFC! (IMG:style_emoticons/default/mueba.gif) Hope all goes well Rick!
M |
| rick 918-S |
Oct 7 2004, 07:18 PM
I've been asked to help out with claims in Florida. I think I managed to convince management to give me a stay until Nov. 1 by offering to work claims down there for 6 to 9 weeks. Usually 3 weeks is average for a rep.
| jim912928 |
Oct 8 2004, 05:35 PM
Progress on my list of to do's:
1. pedal cluster all rebuilt (also stripped and repainted it...POR15'd the area around it)...man the original plastic bushings were really worn! 2. pulled out the clutch cable...about 6" back from the clevis pin thingy the cable was frayed and hanging on by about half of it's strands...I'm lucky 3. brakes are all on and rebuilt..but leaking around the bleeder screws (new ones)...I keep cranking down on them and checking 4. installed all the fresh air vent hoses Tomorrow is another wrench day! |
| cnavarro |
Oct 8 2004, 05:46 PM
Cylinder Guru ![]() ![]() Group: Members Posts: 472 Joined: 30-December 02 From: Chicagoland! Member No.: 49 Region Association: None |
1. Pulled engine and tranny out of the 912 with the father in law today.
2. Tranny goes to Brad monday for a rebuild. 3. Parking brake gets repaired and brakes re-bled. Maybe take tires around the corner to get balanced. 4. Brad comes with tranny and helps me put it in :-) 5. Attend FFC and show off my 912 that Brad put a week of blood, sweat, and tears into! Sounds like a plan, no? Charles Navarro LN Engineering http://www.LNengineering.com Aircooled Precision Performance |
| qa1142 |
Oct 8 2004, 05:57 PM
Whiplash ![]() ![]() ![]() Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
1) change oil
2) once through - Quick once over 3) Pick what tools to pack 4) pack cloths 5) drop kids at nieghbors 6) turn on radar detector (IMG:style_emoticons/default/mueba.gif) 7) top take and drive, drive, drive 8)drink with you all Friday night! (IMG:style_emoticons/default/beerchug.gif) |
| GTeener |
Oct 8 2004, 05:59 PM
914 Girl ![]() ![]() ![]() ![]() Group: Members Posts: 2,348 Joined: 25-June 04 From: SillyCon Valley Member No.: 2,249 Region Association: Northern California |
Only one thing on my list:
Mail out 914 GURL hats as soon as they arrive, so FFC gurls can strut in style (IMG:style_emoticons/default/lol3.gif) |
| jim912928 |
Oct 8 2004, 06:18 PM
Anybody want to start a caravan from those of us up north? Pick a route and pick up others on the way?
| GaroldShaffer |
Oct 8 2004, 06:30 PM
Funny you mention that Jim, Julie & I were just talking about that during dinner. We can leave anytime after 4pm, we have to wait for MIL to get here to watch Nathan. What time were you planning on leaving?
edit: what route are you planning to take. We are taking 94 to I65 south to Columbus. This post has been edited by itsa914: Oct 8 2004, 06:31 PM |
Lo-Fi Version | Time is now: 9th June 2026 - 03:42 AM |
