ss6 |
fun city... ![]() ![]() Group: Members Posts: 261 Joined: 2-February 03 From: Western Connecticut Member No.: 221 ![]() |
About 2 years ago now, I had the gas tank out during my six conversion and touched up some patches of surface rust on the painted metal surrounding the tank with POR-15. (I used their clear stuff 'cause I wanted to keep an eye on some of my welds elsewhere in the car.) Got in there with a wire wheel first to remove the loose rust, but following the mfr's advice:
"Surface preparation: Rusted surfaces are best; seasoned metal and sandblasted surfaces are also good. " So I didn't grind all the way down to shiny metal. OK, 2 yrs later, tank is out again (chasing down a persistent fumes issue). One glance at the POR'd areas and I see NEW rust "spiders" (throught the clear POR) growing out from the original area. Nothing major, no "bubbles", but stuff that clearly wasn't there when I painted it. WTF??? |
ejm |
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,695 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None ![]() |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,682 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
i used metal ready first, the put por-15 over it ...
the metal-ready is supposed to change the rust chemically into, hum, something else ? Andy |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,495 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
"Iron Oxide" But some of the acid preps require a wash down that most people omit.
QUOTE the metal-ready is supposed to change the rust chemically into, hum, something else ? |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,097 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
does the metal ready turn the rust black?
kevin |
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
Rust never sleeps
Lawrence |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None ![]() ![]() |
I haven't visited the POR-15 website in quite a while, except to order. This "scenario" wasn't on there when I researched the stuff a few years ago.
The story they listed didn't mention at all the use of Metal-Ready/Prep, whatever. I'm not sure that it's an issue if you do all the prep steps. -Rusty |
ss6 |
Thanks for pointing out that FAQ response, didn't see it when I went through the site in detail 2 yrs ago. I did use Metal Ready on the area, but the residual moisture thing is quite possible. But for chrissakes, steel is used to HOLD water (and gases, etc), HOW POROUS IS IT??? I didn't know I had to bake the car first <_< . What do car manufacturers do when they start out with ALL bare metal?
So the question now is, does the rusting peter out after awhile (ie after all the "O" in the H2O is converted to FeOx)? I took a pic of the area, and I'm sure I'll be pulling the tank next year for some damn reason or other... |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Yep.
I have pushed and pushed POR15 and it came back to bite me. I put it on a stock battery tray that was solid... 2 years later... rust.. just like before. It was the first time I had used the POR. B |
Dave Cawdrey |
Dumbo going poop, Daddy :) ![]() ![]() ![]() Group: Members Posts: 818 Joined: 22-January 03 From: Seattle, WA USA Member No.: 182 ![]() |
QUOTE(rhodyguy @ May 11 2003, 05:21 AM) does the metal ready turn the rust black? kevin No, it turns white... |
markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California ![]() ![]() |
So what should I use, if not POR15? (IMG:style_emoticons/default/sad.gif)
Dave Cawdrey |
QUOTE(markb @ May 11 2003, 10:07 PM) So what should I use, if not POR15? (IMG:style_emoticons/default/sad.gif) Use POR 15, just not that clear shit. If you want the bare metal look, use Metal Mask. |
Lo-Fi Version | Time is now: 13th June 2024 - 04:26 AM |
