| bfrymire |
Jun 2 2012, 08:02 PM
Salsaholic ![]() ![]() ![]() Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
Just like the thread says:
I am putting this in: (This has been posted in the Elephant racing poly bronze thread from the other day.) ![]() Here's the driver side prepped and waiting to install. ![]() Here's the passenger side installed. ![]() GPR supplied the parts and did the setup for me. It has around 1 degree of negative camber as I am running Hoosier A6s. Bump steer kit also installed. I also have their front sway bar, and will be installing that next. Heh, I can sure tell I don't do this for a living. It took me a couple of hours to install and I still may take it apart again. (IMG:style_emoticons/default/smile.gif) -- brett |
| okieflyr |
Jun 2 2012, 08:09 PM
9fauxteen ![]() ![]() ![]() Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States |
I love the tuneability factor. Does the shock tower have or get any reinforcement?
| bfrymire |
Jun 2 2012, 08:38 PM
| effutuo101 |
Jun 3 2012, 12:03 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,738 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
Like!
| Mike Bellis |
Jun 3 2012, 12:11 AM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Very cool. I think it may be a good idea to strengthen the shock towers. Even if just for piece of mine.
| RSrocket |
Jun 3 2012, 02:03 AM
Newbie ![]() Group: Members Posts: 29 Joined: 26-May 12 From: Carson, CA Member No.: 14,480 Region Association: Southern California |
Nice set up, me likes!
| carr914 |
Jun 3 2012, 03:52 AM
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 131,990 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Nice ! I will be doing the same thing to my 911 soon
| lotus_65 |
Jun 3 2012, 04:17 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,609 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
looks spendy...
nice though! |
| pjhaun |
Jun 3 2012, 08:30 AM
Member ![]() ![]() Group: Members Posts: 370 Joined: 21-August 03 Member No.: 1,055 Region Association: None |
How much does that cost?!!!!!
| 0396 |
Jun 3 2012, 09:02 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Me likes..what's the spring rate? ...enjoy in good health!
| brant |
Jun 3 2012, 09:06 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,167 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
I don't see people with coil overs really ever changing springs
| McMark |
Jun 3 2012, 09:08 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
| Andyrew |
Jun 3 2012, 09:17 AM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
Whats the advantage here?
All I see is less tire space and higher COG |
| brant |
Jun 3 2012, 09:22 AM
If you go to a full 935 adjustable a-arm you can ditch the stock a-arm, save weight without it, and gain adjustability if you ditch the stock a-arm
also if you change springs for every event, or a couple of times a day it is slightly easier than changing torsion bars. (But really no 914 racers change spring rates for every event like a pro team would.) |
| stuttgart46 |
Jun 3 2012, 09:40 AM
Member ![]() ![]() Group: Members Posts: 305 Joined: 17-December 07 From: Santa Monica, CA Member No.: 8,474 Region Association: None |
Is this for a track only car or will it still be streetable?
Nice looking set up BTW. |
| bfrymire |
Jun 3 2012, 11:19 AM
I am using 200lb springs for the initial setup, and am quite sure that will change. It's going to be interesting to see how the car handles afterward. This is a street/track car. It spends most of it's time autocrossing, but I do sometimes drive it around. And this leads into the 935 a-arms. I looked at those, and asked about them also. I was told that they would be too fragile in street use. Too bad.
The advantages are better variety of springs, larger range of height adjustment, and as someone said, slightly eaiser to change springs. I would be curious to hear from someone who has tracked this setup. (IMG:style_emoticons/default/smile.gif) Costwise, I try not too look at the recipts too much. (IMG:style_emoticons/default/smile.gif) I had GPR do all the welding that needed to be done, and the installation of the ER Polybronze. I am a hobbiest-mechanic and didn't want to mess that part up. So: This is $349 http://www.tarett.com/items/914-products/9...rcom-detail.htm Add in bilstein shocks. (Don't remember the cost offhand. Can be found online.) ER Polybronze set: http://www.tarett.com/items/914-products/9...1x00-detail.htm I then had to get a pair of 911 struts. Used around $600 or so. I also added the bump-steer kit. About $289. http://www.tarett.com/items/914-products/9...rbsk-detail.htm I am sure i am forgetting something... (IMG:style_emoticons/default/smile.gif) -- brett |
| jmill |
Jun 3 2012, 12:52 PM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
You can buy the entire setup from Rebel Racing.
| SUNAB914 |
Jun 3 2012, 01:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
I know a guy locally that has those for sale on craiglist in Washington DC.
| stuttgart46 |
Jun 4 2012, 09:11 AM
| bfrymire |
Aug 12 2012, 06:14 PM
Update.
All installed and drove it. Ran into to plenty of snafus, but finally did get it done. Has the GPR 21 mm front sway bar also. 1. Is this too low? about 4.5 inches from the jack point, and 5 inches in the rear. (Not corner balanced yet.) 2. I am getting a funny noise in a tight turn, something is rubbing. Need to troubleshoot that still. Ok. Here's some pics. -- brett ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:37 PM |
