Oil pressure gauge and fuel gauge problems |
tornik550 |
Jun 9 2012, 08:53 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I was playing around with my gauges. For some reason, my oil pressure gauge goes all the way to the right (the far extreme high pressure) as soon as I turn the key- even before the starter engages. I have checked all of the wiring, cannot find any problems. I noticed that when I turn the key off, the gauge does not return to normal right away. Any ideas?
Also, I have had this problem for years, my fuel gauge only reads full. I have checked the sender and it moves up and down freely. Any ideas how to fix. I obviously, do not have a good understand of how these gauges work. |
partwerks |
Jun 9 2012, 10:28 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
I don't know if an oil pressure switch would have anything to do with it or not?
The fuel float can be taken apart and look to see if there are any rust spots or something that could be causing it to hang up on?? |
Porschef |
Jun 10 2012, 04:58 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Oil pressure or temperature? If its the temp, and they're both on the gauge in the dash, I'd think it's a ground issue
rwilner |
Jun 10 2012, 07:40 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
TheCabinetmaker |
Jun 10 2012, 10:45 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Is the oil pressure gauge in the dash or the console? Is this a 4 or 6? I don't think 4's came with an oil pressure gauge, just a light on the combo gauge. If there is an actual "pressure" gauge, its an add on.
tornik550 |
Jun 10 2012, 11:42 AM
tornik550 |
Jun 10 2012, 07:36 PM
I haven't messed with the fuel gauge yet but the problem with my oil pressure gauge was the wire from teh sender to the gauge. It was cracked in the tunnel. Put in a new wire and now everything works perfectly. Thank you to everyone. The egauges pdf was especially helpful.
Lo-Fi Version | Time is now: 8th June 2024 - 03:36 AM |
