WTB: harness from relay board (engine side), really just need the connector so if yours is hacked it's OK |
Rotary'14 |
Jun 11 2012, 09:07 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
I need the harness that goes from the relay board to the reverse light switch, starter, etc. I just need the connector, but I'll buy the harness if I have to.
what do you folks have? -Robert |
MiddleGACruiser |
Jun 18 2012, 05:32 PM
Hobbits? What Hobbits? Group: Members Posts: 115 Joined: 5-September 04 From: Porschenaire, GA Member No.: 2,694 Region Association: None |
I need the harness that goes from the relay board to the reverse light switch, starter, etc. I just need the connector, but I'll buy the harness if I have to. what do you folks have? -Robert I have a harness from a '72. It's not totally complete. Do you have a picture of what you need so I can see if I have it? Jeff |
Krieger |
Jun 19 2012, 10:07 AM
Advanced Member Group: Members Posts: 4,723 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I could use a couple of parts too if we could work something out. I need the rubber boot and the two ends that plug into the transmission. Just those two metal barrels that go into the backup switch that are on the harness.
Rotary'14 |
Jun 19 2012, 12:51 PM
Thanks guys,,
It turns out I found the one I was missing in the mess I call a garage. -Robert |
MiddleGACruiser |
Jun 19 2012, 02:54 PM
I could use a couple of parts too if we could work something out. I need the rubber boot and the two ends that plug into the transmission. Just those two metal barrels that go into the backup switch that are on the harness. I no longer have a 914 to look at, but I do have a bunch of parts that need new homes. I looked at the harness and It has 2 brown wires that come from the same feed as what appears to be the starter feed. Unfortunately the end is gone. If this is what you're looking for then it's already found a new home at some point. Got a picture? Jeff |
somd914 |
Jun 19 2012, 08:01 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
I could use a couple of parts too if we could work something out. I need the rubber boot and the two ends that plug into the transmission. Just those two metal barrels that go into the backup switch that are on the harness. For the reverse light switch, I've found common (any car parts store) crimp on male snap plugs work if you pry open the plug a little to make a tight fit in the switch. It's not factory, but it works well. |
Krieger |
Jun 19 2012, 09:37 PM
I could use a couple of parts too if we could work something out. I need the rubber boot and the two ends that plug into the transmission. Just those two metal barrels that go into the backup switch that are on the harness. For the reverse light switch, I've found common (any car parts store) crimp on male snap plugs work if you pry open the plug a little to make a tight fit in the switch. It's not factory, but it works well. Thanks, but Im trying to go original. |
Lo-Fi Version | Time is now: 1st June 2024 - 07:22 PM |
