QUOTE(Krieger @ Jun 19 2012, 12:07 PM)
I could use a couple of parts too if we could work something out. I need the rubber boot and the two ends that plug into the transmission. Just those two metal barrels that go into the backup switch that are on the harness.
For the reverse light switch, I've found common (any car parts store) crimp on male snap plugs work if you pry open the plug a little to make a tight fit in the switch. It's not factory, but it works well.
