Removing stock fuel lines.., Whats the procedure for getting them out? |
speed metal army |
Jun 17 2012, 02:40 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
Tank end first?And yank em through?
pilothyer |
Jun 17 2012, 03:05 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
That's pretty much it.....push the lines through the large grommet from the tank area, and if possible unclip the lines inside the tunnel than go to the rear and pull them through.
speed metal army |
Jun 17 2012, 03:21 PM
Mines a late car. Dont knowif that makes any difference.. So i cant pull the whole works through the tank area?
jhora |
Jun 17 2012, 03:52 PM
Newbie Group: Members Posts: 26 Joined: 6-March 09 From: Kentucky Member No.: 10,138 Region Association: South East States |
I just did this....
I removed them from the rear at the engine fire wall...right by the speedo cable...my engine is out there are two of those little fold over metal clips in the tunnel holding them(these are like the ones holding most elec wires in both trunks) they are accessable from the shifter adjuster lid and under the shifter area... cafefully bend them up and the lines will pull out very easy...my be a little stiff at both the front an rear firewall rubber grommets I pull both lines at the same time with out any problem... Good Luck....John |
pilothyer |
Jun 17 2012, 04:42 PM
Mines a late car. Dont knowif that makes any difference.. So i cant pull the whole works through the tank area? Not very easily.......the lines at the tank end are steel with a bend and are about 20 inches long before the plastic tubes.......very much easier to remove from the rear. |
speed metal army |
Jun 17 2012, 07:06 PM
Done! It was actually easier to pull them back to the shifter access hole, then out of the same hole. When pulling from the firewall they wanted to hang up on something...
Thanks for the tips ! |
jhora |
Jun 17 2012, 07:26 PM
Jerry...you're right...sorry...mine was a 70 914-6...the early ones had no metal pipe on the plastic lines at the tank end...just hose all the way....thanks for the correction....
gothspeed |
Jun 18 2012, 11:17 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Done! It was actually easier to pull them back to the shifter access hole, then out of the same hole. When pulling from the firewall they wanted to hang up on something... Thanks for the tips ! I am getting ready to do this same task. So that is good info (IMG:style_emoticons/default/smile.gif)! What lines will you be putting in? Will you be installing the new lines through the firewall first? |
JawjaPorsche |
Jun 18 2012, 11:48 AM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
Yes, because of the angle. You don't want to bend the steel lines.
speed metal army |
Jun 18 2012, 07:31 PM
Done! It was actually easier to pull them back to the shifter access hole, then out of the same hole. When pulling from the firewall they wanted to hang up on something... Thanks for the tips ! I am getting ready to do this same task. So that is good info (IMG:style_emoticons/default/smile.gif)! What lines will you be putting in? Will you be installing the new lines through the firewall first? I will be installing 3/8" SS tube.Yep! Thru the firewall. |
stugray |
Jun 18 2012, 08:13 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Too late, but I pulled wire through the tunnels when pulling the old lines out.
That made it easier to pull the new lines in ;-) For the new lines, I used 5' of steel brake line from the FLAPS. They went in almost perfectly straight except the last few inches under the tank where I needed a kink or two. Stu |
Bartlett 914 |
Jun 19 2012, 07:10 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I just installed a set of SS lines. Drivers seat and center console is out. This gave me easy access to the plate on the top of the tunnel in front. There you can see the lines going into the rubber plug into the front. I pulled the lines out there and pushed the plug into the tank area. Old lines were easy to get out ans I pushed the new ones in easily. Used a little soap to lubricate the rubber for the tubes and to make it easier to push back in place.
Lo-Fi Version | Time is now: 1st June 2024 - 06:45 PM |
