WTB metal ends from harness for back up light switch and rubber boot, who has a hacked up engine harness |
Krieger |
Jun 28 2012, 11:22 PM
Advanced Member Group: Members Posts: 4,718 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I need the two metal ends that plug into the back up light switch on the trans and the rubber boot that covers them. I don't want an entire harness.
76-914 |
Jun 29 2012, 08:12 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I need the two metal ends that plug into the back up light switch on the trans and the rubber boot that covers them. I don't want an entire harness. If you can't find the male plugs you can use "blue" butt splice connectors. Strip the plastic off, crimp one end on the wire, slightly enlarge the open end with a small nail or ice pick then slide it in the back up switch. |
Krieger |
Jun 29 2012, 08:50 AM
Thanks, I'm looking to do it oem style.
bdstone914 |
Jun 29 2012, 10:00 AM
bdstone914 Group: Members Posts: 4,524 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Krieger |
Jun 29 2012, 06:45 PM
When do you think you will make your next run to the bone yard? How much $
bdstone914 |
Jun 29 2012, 08:19 PM
Krieger |
Jun 29 2012, 09:27 PM
Thanks, let me know!
IronHillRestorations |
Jun 29 2012, 10:25 PM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I've got some suitable bullet connector replacements that work fine for the connectors. A new boot is the only way to go. I might have a new boot. PM me if your interested. Once you put the boot on, you are the only one that's going to know they aren't factory connectors.
toolguy |
Jun 30 2012, 11:36 AM
Senior Member Group: Members Posts: 1,268 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
the metal 'bullets' are the same as used in other places on the car. . like the multi pin plug on the engine circuit board and the pins inside the ignition switch IIRC. .
Just unsolder them off an old harness and reuse. . |
Krieger |
Jul 6 2012, 05:23 PM
JeffBowlsby |
Jul 6 2012, 07:35 PM
914 Wiring Harnesses Group: Members Posts: 8,513 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
the metal 'bullets' are the same as used in other places on the car. . like the multi pin plug on the engine circuit board and the pins inside the ignition switch IIRC. . Just unsolder them off an old harness and reuse. . No...they are different and unique to the reverse light switch. Kreiger...did you get my email/PM from last week? I can hook you up... |
Lo-Fi Version | Time is now: 23rd May 2024 - 12:51 AM |
