Type 47 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 791 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None ![]() ![]() |
on the surface it just seems that the rotors need to be drilled for the 5 lug studs...what am I missing?
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,892 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
Check the classic threads section.
http://www.914world.com/bbs2/index.php?act=SF&s=&f=5 You can just drill the hubs, but its not the recommended way. I'm running 911 rear hubs and rotors with Swayaway axles. In the front I am just running 911 3.5" struts. I then used Boxster adapters to use Boxster brakes front and rear. I am also using a 911 parking brake. Drilling the hubs is not as strong as using the stock 911 components. I also don't think its supported for track events, but I could be wrong. |
Type 47 |
Check the classic threads section. http://www.914world.com/bbs2/index.php?act=SF&s=&f=5 You can just drill the hubs, but its not the recommended way. I'm running 911 rear hubs and rotors with Swayaway axles. In the front I am just running 911 3.5" struts. I then used Boxster adapters to use Boxster brakes front and rear. I am also using a 911 parking brake. Drilling the hubs is not as strong as using the stock 911 components. I also don't think its supported for track events, but I could be wrong. Thanks...I bookmarked the link. I ddn't realize there was a classic section. |
Lo-Fi Version | Time is now: 19th July 2025 - 06:05 AM |
