billh1963 |
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States ![]() |
Looks pretty far gone to me; however, I am by no means an expert. This is the '73 2.0 head off the car I picked up this weekend. Engine dropped a valve...
(IMG:http://www.914world.com/bbs2/uploads_offsite/i268.photobucket.com-12871-1343069023.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i268.photobucket.com-12871-1343069023.2.jpg) |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Just depends on how much money you want to throw at it. They're aluminum and can be built back up and machined back.
billh1963 |
Well, I guess it was more a question of would it be worth it? Sounds like the answer is NO ...
ottox914 |
The glory that once was. ![]() ![]() ![]() Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest ![]() ![]() |
No kidding, dropped a valve... Can be fixed, depending on who you get and how much you want to "drop" on the repairs. I'd shop around for bids on the repair, as well as the reputation of the builder. You don't want someone who will take your money and make LOOK right, you need someone who can make it WORK right. A good inspection of the head may show other problems that in total, would make a different head to re-build a better option for you.
Len Hoffman at H.A.M. is well known around here. Perhaps he'll chime in, although he stays plenty busy with the shop and is not always online. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,594 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Its cheaper to start witha head that has not dropped a valve.
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,731 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
That would not be worth fixing
billh1963 |
I figured as much...just checking! (IMG:style_emoticons/default/sad.gif)
HAM Inc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None ![]() |
I have repaired damage that was on par with that before. Years ago I pulled away from that sort of salvage work for heads that are not rare and/or valuable.
JCS or GEX would probably buy it for more than scrap value. |
Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
Those kind of heads usually get rebuild with bigger valves. It makes sense since most of the work needs to be done anyway to accommodate the bigger valves.
If you think of dumping them, I'll gladly take them for my planned big 4 engine. Just PM me. |
billh1963 |
Those kind of heads usually get rebuild with bigger valves. It makes sense since most of the work needs to be done anyway to accommodate the bigger valves. If you think of dumping them, I'll gladly take them for my planned big 4 engine. Just PM me. Not sure of my plans but you'll be first up if I get rid of them! |
worn |
can't remember ![]() ![]() ![]() ![]() Group: Members Posts: 3,175 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
Looks pretty far gone to me; however, I am by no means an expert. This is the '73 2.0 head off the car I picked up this weekend. Engine dropped a valve... (IMG:http://www.914world.com/bbs2/uploads_offsite/i268.photobucket.com-12871-1343069023.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i268.photobucket.com-12871-1343069023.2.jpg) I guess my only thought is that it is from a 2.0 and therefore a bit special. Yeah, now you can get one for maybe less than the rebuild. As far as I know they aren't making them anymore, and these are the true Porsche parts of the 914-4. |
Lo-Fi Version | Time is now: 16th June 2024 - 10:47 PM |
