HEADLIGHT OPERATIANG HALFWAY NEWB, . |
vwlurch |
Jul 25 2012, 04:51 PM
Newbie Group: Members Posts: 8 Joined: 13-December 10 From: ohio Member No.: 12,483 Region Association: None |
so i just hooked power up to the car and i have a headlight that only comes up 1/4 of the way .if you spin the screw it will catch at 1/2 way and make a finished closed cycle then back to 1/4 open again ..?the po painted the car completly in and out is there something that could be out of place off sync? and my headlight s and fog light s wont turn on and no power to the fuses i pulled the switch apart and didnt see anything wrong .cleaned it and relubed it with dielectric grease havent hooked power to it yet but dont think its the issue.headlights have no power at plug either.
SirAndy |
Jul 25 2012, 05:11 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
so i just hooked power up to the car and i have a headlight that only comes up 1/4 of the way .if you spin the screw it will catch at 1/2 way and make a finished closed cycle then back to 1/4 open again ..?the po painted the car completly in and out is there something that could be out of place off sync? and my headlight s and fog light s wont turn on and no power to the fuses i pulled the switch apart and didnt see anything wrong .cleaned it and relubed it with dielectric grease havent hooked power to it yet but dont think its the issue.headlights have no power at plug either. http://www.914world.com/specs/headlight_adjustment.php Watch your fingers! (IMG:style_emoticons/default/smash.gif) |
vwlurch |
Jul 25 2012, 05:17 PM
this will cause it to not operate all the way?
Dave_Darling |
Jul 25 2012, 09:17 PM
There are switches inside the motor assembly. They tell the motor when to start and stop. So if they're not in the right place, the light won't stop in the right place.
--DD |
Lo-Fi Version | Time is now: 1st June 2024 - 11:35 PM |
