New Gauges |
New Gauges |
ww914 |
Aug 1 2012, 08:23 AM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
Awhile back some of us group bought CHT gauges and wideband air/fuel mixture gauges. Any reports on how they are working out for you?
It may be overkill, but I love my CHT display. It may be more info than I need, but it's nice to see what is going on. As far as the air/fuel gauge goes, I absolutely think that this is the only way to go to tune your carbs to perfection. I am sure this has been said before, but now I am a true believer. I can't keep my eye off the dam thing. Not sure if that is a good thing or not, but I sure know if I am running lean or rich at every throttle position. I suppose when I get it tuned they way I want, I won't stare at it as much. Here are the three new gauges I have installed: The top one is the MGL Avionics TC-2 4 channel CHT gauge. The middle one is the AEM Wideband Air/Fuel Ratio gauge. The bottom one is an oil pressure gauge. I built this new insert and saved the original setup. This is how I installed the probes. I didn't use existing spark plugs holes, but cut new holes and inserted grommets. |
wndsnd |
Aug 1 2012, 09:58 AM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Awhile back some of us group bought CHT gauges and wideband air/fuel mixture gauges. Any reports on how they are working out for you? It may be overkill, but I love my CHT display. It may be more info than I need, but it's nice to see what is going on. I probably missed it but did you repost what guages you are using and possibly a picture? |
bembry |
Aug 1 2012, 04:44 PM
Senior Member Group: Members Posts: 529 Joined: 29-July 05 From: Bakersfield, CA Member No.: 4,499 Region Association: MidAtlantic Region |
How much did those run you?
jsayre914 |
Aug 1 2012, 05:16 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
Looks great!
I have got the leads on my plugs but still have not had time to hook up the gauge. I have been busy gettin all the bugs worked out, the gauge is next on my list. (IMG:style_emoticons/default/beerchug.gif) |
ww914 |
Aug 1 2012, 05:25 PM
aharder |
Aug 1 2012, 06:48 PM
Advanced Member Group: Members Posts: 4,410 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
Looks Great !! (IMG:style_emoticons/default/beerchug.gif)
Eric_Shea |
Aug 2 2012, 07:05 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Good work Warren.
rnellums |
Aug 2 2012, 07:17 AM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
Did you remove the engine to put the CHT's on? or just the engine tin? or are you a magician? I'm trying to decide whether to drop the motor out of the racecar to do it or not.
ww914 |
Aug 2 2012, 07:47 AM
Did you remove the engine to put the CHT's on? or just the engine tin? or are you a magician? I'm trying to decide whether to drop the motor out of the racecar to do it or not. No, I am not a magician, I actually drilled the holes and attached the leads before I installed the engine. I did not remove the engine tins. I did rig up a small hose on my shop vac to catch most of the drilling debris that was inserted through the tin spark plug hole. The idea here is to be able to see the lead in place before installing the spark plugs. Of course, it is easy with the engine out. Haven't done it yet with the engine in. |
Lo-Fi Version | Time is now: 7th June 2024 - 08:55 PM |
