stiff gear change, stiff gear change |
cal914 |
Sep 8 2012, 01:27 PM
Member Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None |
recently bought a 914 took it out for its first drive after having some work done on it and i'm having trouble changing up from first to second very stiff and clunky also when in neutral very floppy keep putting in to 3rd gear any ideas
Mike Bellis |
Sep 8 2012, 01:33 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Replace the shift bushings and re-adjust the rod.
cal914 |
Sep 8 2012, 01:44 PM
also it's a bit crunchy when putting into second
Mike Bellis |
Sep 8 2012, 01:54 PM
You could try to tighten the clutch cable 1-2 turns and see if it gets better. Worst case, you need a rebuild. The crunch and sloppy shifting are two different issues.
Does it crunch going into reverse? Yes= tighten clutch cable. No= possible bad syncro on 2nd grear, try to tighten cable a little. |
cal914 |
Sep 8 2012, 02:04 PM
to rebuild is that expensive would a VW transmission work or are they totally different
Bartlett 914 |
Sep 8 2012, 02:21 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I would change the oil first an go from there.
Mike Bellis |
Sep 8 2012, 02:23 PM
to rebuild is that expensive would a VW transmission work or are they totally different Totally different transmissions. Not sure what it costs in the UK to rebuild. You could call Dr. Evil (Transmission Guru) I'm sure he would be willing to come to you for a fee. |
ThePaintedMan |
Sep 8 2012, 02:24 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
to rebuild is that expensive would a VW transmission work or are they totally different As others have said, start with something cheap, like all of the bushings. To answer you question though, no a VW trans won't work, or not without some serious engineering. VWs are rear engine, our cars are mid. Therefore, you would not only have 4 gears, but 4 gears in the wrong direction. Again, start with bushings, probably a trans oil change as well. After that, you would then start worrying about rebuilding it. |
cal914 |
Sep 8 2012, 02:44 PM
were is DR evil based in UK or USA thanks
Mike Bellis |
Sep 8 2012, 05:54 PM
Mr Pharmacist |
Sep 10 2012, 05:57 AM
Member Group: Members Posts: 69 Joined: 15-September 09 From: United Kingdom Member No.: 10,807 Region Association: England |
Mike Bainbridge is your man in the UK - based near Kendal
matt5596 |
Sep 13 2012, 08:53 AM
Member Group: Members Posts: 102 Joined: 28-September 11 From: Norris, TN Member No.: 13,619 Region Association: South East States |
recently bought a 914 took it out for its first drive after having some work done on it and i'm having trouble changing up from first to second very stiff and clunky also when in neutral very floppy keep putting in to 3rd gear any ideas My new to me '71 with original tail-shifter behaves the same way - real stiff exiting 1st gear although no crunching into any gear. I've found that if I push the shifter a bit to the left before pushing it up out of 1st, it shifts very smooth. (IMG:style_emoticons/default/screwy.gif) Works every time - trick is not to push it too far left or you'll nick reverse on the way to 2nd. (IMG:style_emoticons/default/headbang.gif) I'm guessing that new bushings and an adjustment are in my future. |
Lo-Fi Version | Time is now: 12th June 2024 - 01:17 AM |
