SOLD: 914 2.0 long block+, mostly complete $450 |
RoadGlue |
Sep 25 2012, 09:47 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
Hi! This motor needs to get off the floor of my garage. Make me an offer, please! I also have a slew of other 914 parts, some of which I may be able to throw in to sweeten this deal further. As-is, this motor will work as either a great basis to build a GA 2.0 motor, or just fix the galley plug and use a complete long-block. See further info below, and ask me any questions you may have. I'm selling one of my '74 2.0 motors as I'm building a new motor for the car based on a short stroke setup. The motor worked fine, the heads look clean when looking from beneath. It ran great before I pulled it OTHER than the fact that it blew an oil galley plug near the oil cooler Thankgiving morning. Thankfully this happened on my block, and the motor was stopped as soon as the light came on. I pulled the motor and swapped it with the motor out of my other 914. The motor has sat since, with the other car in the air since. Shameful! I know. Other than the galley plug that needs fixing, I remember seeing that one of the wires poled out of one or two of the injectors. It's old. It needs fixing or replacing. $450 includes the long block (complete minus a galley plug) and the following: - Flywheel and Clutch - 90% of the FI system, though I may have used the ECU in my other car, so no ECU - The two 2.0 pieces of tin, the rest I need to keep - GA Case Does not include (here are the main items): - Cooling fan or housing - Distributor - Misc bits What you're mostly buying is a complete long block, everything else that's included are bonuses. (IMG:style_emoticons/default/smile.gif) The motor is located in my house's garage in Santa Rosa, CA (about an hour north of San Francisco). Come look at it if you're interested. Pickup only. PM offers, post questions here. Thanks! Randy |
RoadGlue |
Sep 26 2012, 12:10 PM
Also willing to deliver now within 50 miles of Santa Rosa, CA. Would rather not, but I really want to make room for my new project and motorcycle. Thanks!!
McMark |
Sep 26 2012, 03:05 PM
Done!
RoadGlue |
Sep 26 2012, 03:13 PM
(IMG:style_emoticons/default/smile.gif) Thank you Mark!
Lo-Fi Version | Time is now: 2nd June 2024 - 01:07 PM |
