2.0L crank dimensions, I need to order bearings |
Harpo |
Oct 7 2012, 12:31 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Below are my dimensions for the rod journals
Main------- rod rod main rod rod main 59.76 49.86 49.68 59.68 49.72 49.71 59.69 59.81 49.84 50.81 59.68 49.78 49.71 59.70 59.70 49.70 49.77 59.78 49.83 49.82 59.74 59.70 49.69 49.73 59.66 49.72 49.71 59.66 What size bearings do I need? The condition of the journal seems really good and the previous owner though it was polished. Thanks DAvid |
VaccaRabite |
Oct 7 2012, 05:46 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
If you are asking this question, this is something you should get a machinist to help you with.
Harpo |
Oct 7 2012, 06:32 PM
Yes I will also be covering this with a local machine shop but I have never done busines with them before. I just want to be a knowledgable consumer.
Thanks David |
Valy |
Oct 7 2012, 10:26 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Your readings are not consistent so it's either that you're not measuring well or the crank needs to be ground.
The bearings come in 0.25mm increments on the crank side. You also missed the case size measurement that is very important when choosing the bearings. On this measurement, the steps are STD or +0.5mm. The middle split bearing is the most abused. |
rhodyguy |
Oct 9 2012, 09:27 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
if the case has been or will need to be align bored you'll need the appropriate over size ones.
Cap'n Krusty |
Oct 9 2012, 09:30 AM
If you're not messing with the bore and just polishing the crankshaft, read the numbers off the old bearings and order the same ones.
The Cap'n |
Lo-Fi Version | Time is now: 11th June 2024 - 03:28 PM |
