| porbmw |
Oct 22 2012, 02:06 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 818 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None
Are the tail shifter rear linkage covers the same for both 4s and 6s....Don't know WHY they would differ, but then.....
IF so, any sources out there for a clean unmolested one...(and if they different, any soucrecs for one going to a 6? Thanks Paul |
| gms |
Oct 22 2012, 02:08 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,758 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest
Are the tail shifter rear linkage covers the same for both 4s and 6s....Don't know WHY they would differ, but then..... IF so, any sources out there for a clean unmolested one...(and if they different, any soucrecs for one going to a 6? Thanks Paul The 4 and 6 rear transmission covers are different (as well as the linkage) |
| porbmw |
Oct 22 2012, 05:58 PM
Are the tail shifter rear linkage covers the same for both 4s and 6s....Don't know WHY they would differ, but then..... IF so, any sources out there for a clean unmolested one...(and if they different, any soucrecs for one going to a 6? Thanks Paul The 4 and 6 rear transmission covers are different (as well as the linkage) Thanks. That pretty well figures.... Maybe I'd better ask this..... Original 6 tranny, courtesy of T.C., with sideshift conversion courtesy of the good Dr. Evil.... Still need cover for a 6???? |
| toolguy |
Oct 22 2012, 06:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,277 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California
The six cover is taller, no way to make a 4 fit on a 6 linkage. . They are extremely hard to find, and no such thing as a new one from Porsche anymore. . I had the factory do a search in 2011 and there are none anywhere in any dealers stock. . .
I finally found one after a year long search, it came off a 6 tailshifter that the owner converted to side shift. . George at AA was going to make a repop a year ago and he never got enough orders to make the mold worth the cost. . IIRC, he was going to charge $100 a copy. . When you could get them 10 years ago they were less than $50 for a new one |
| porbmw |
Oct 22 2012, 10:51 PM
OOOPs (IMG:style_emoticons/default/poke.gif) I"m a thinkin' and a hopin you may have answered my question....! (IMG:style_emoticons/default/beerchug.gif) |
| GeorgeRud |
Oct 23 2012, 11:38 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Actually, I can't think of any reason to not simply convert any 914 Trans to a side shifter if that's an option. I replaced the original transmission in my -6 with one, and the shifting is definitely nicer and tighter. Of course, I kept the original parts for originality purposes, but the side shifter is nicer.
The original -4 transmission had somewhat of a monkey motion linkage in my opinion. Later designs made more sense. |
| rudedude |
Oct 23 2012, 12:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 575 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest
Does the side shift linkage interfere in any way with stock six heat exchangers or anything else?
Thanks |
| GeorgeRud |
Oct 23 2012, 04:13 PM
I have factory heat exchangers on both of my cars ( one a 914 side shifter, and the other a vellios 915), and there were no interference problems on either.
| gms |
Oct 25 2012, 08:09 AM
| porbmw |
Oct 25 2012, 11:15 AM
Does the side shift linkage interfere in any way with stock six heat exchangers or anything else? Thanks I had to alter the stock 4 rear linkage piece to work around a 6 exhaust. Even if I ask, guess it won't make much difference, will still have to deal with it...but ... Was the 6 exhaust stock/heat exchangers....or headers.... |
| brant |
Oct 25 2012, 11:41 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,283 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
on my 6 with headers and a side shift....
the shift bar can literally be straight this eliminates the curves of a stock -4 side shift bar that lead to more flex it makes sense to produce a new bar with the optimum (or zero if you can) number of curves... |
| porbmw |
Oct 25 2012, 04:50 PM
on my 6 with headers and a side shift.... the shift bar can literally be straight this eliminates the curves of a stock -4 side shift bar that lead to more flex it makes sense to produce a new bar with the optimum (or zero if you can) number of curves... Makes sense, and will be done when I get there...trying to get a bunch of ducks in a row. Thanks |
| Eric_Shea |
Oct 25 2012, 07:24 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Paul, use the side shift and get a used sideshift cover. You will have to stand off your -6 exhaust mount about 1" but otherwise, it's a clean install.
Brant's correct. I used a straight linkage rod. With the Rennshift Level III kit below and factory HE's I had a little issue back by the tranny console but, I think my HE's were bent a tad. The -6 linkage is better than the -4 linkage and the sideshift linkage is better than the -6 linkage. My "stock" shift lever is "very" notchy and precise now. |
| porbmw |
Oct 25 2012, 10:39 PM
Paul, use the side shift and get a used sideshift cover. You will have to stand off your -6 exhaust mount about 1" but otherwise, it's a clean install. Brant's correct. I used a straight linkage rod. With the Rennshift Level III kit below and factory HE's I had a little issue back by the tranny console but, I think my HE's were bent a tad. The -6 linkage is better than the -4 linkage and the sideshift linkage is better than the -6 linkage. My "stock" shift lever is "very" notchy and precise now. I was pretty happy with the stock 6 shift....can't wait to see how this will turn out. Thanks for all the help! (IMG:style_emoticons/default/smilie_pokal.gif) |
| Eric_Shea |
Oct 26 2012, 01:39 PM
Here's where I ran into issues...
It's not the pipe that's clearly visable in this shot, it's the middle pipe that's kind of darker behind it: (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-a.xx.fbcdn.net-1110-1351280345.1.jpg) Again, I think my HE's were tweaked a bit but this was an easy fix with an acetolyne torch. I would encourage you to find something similar here: (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-1110-1351280346.2.jpg) I believe James is no longer making these but, my assumptions were confirmed upon the first drive. The linkage is where 80% of the slop is (if not more). I needed to keep a stock shift console for the hand throttle and appearance in my build. I used a weltmeister SS kit and the Rennshift stuff down below. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-a.xx.fbcdn.net-1110-1351280346.3.jpg) |
| brant |
Oct 26 2012, 02:39 PM
Here is ours... a straight-hollow-cromoly bar with twin apex joints.
the shifter inside is an AJRS special we literally cut an ear off of a second housing and tig'd it onto this shift housing to make a double support for the longer linkage. the brass bushings are custom reamed to fit. cover not pictured, but we made one similar to Eric's you can also see we have a custom extended cup bushing holder... basically all of it is custom. a hand machined delrin firewall bushing too.... Attached image(s)
| Dr Evil |
Oct 26 2012, 06:18 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,044 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
I probably have a /6 cone if you are interested.
Lo-Fi Version | Time is now: 30th October 2026 - 04:46 AM |
