| Hine62 |
Oct 22 2012, 03:50 PM
Member ![]() ![]() Group: Members Posts: 132 Joined: 4-October 12 From: Binghamton, NY Member No.: 15,000 Region Association: None |
I need to put a new clutch disk in my 914. Can I just upgrade to the 911 six spring or do I need to replace the pressure plate also? (Bearing will be replaced too.)
Hine62 |
| 76-914 |
Oct 22 2012, 04:02 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,867 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
any self respecting mechanic is going to R&R them as a unit. And I don't blame them. Recalls are a bitch. That being said I did it. In fact, I done worser than that. I put a used disc in my white one 3 yr's ago. Then again I don't horse my clutch. I drive my car hard but I don't need much from a disc in an 88hp 2000lb car. (IMG:style_emoticons/default/beerchug.gif)
| mr914 |
Oct 22 2012, 04:49 PM
914 Hillbilly ![]() ![]() ![]() Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
Depends on the usage, and how good of a driver you are..
I've been using the same pressure plate for20 years... Seem to go thru more core motors than clutches... W/ 2-4 track days per yer Look for wear, grooving on the p plate blur hot spots on the clutch or pplate Then it's a matter of, if you fix it yourself (IMG:style_emoticons/default/smash.gif) or pay someone else... If you are a checkbook jockey, Payton put the whole kit in. You do it yourself... Think, it only takes a couple of hours to swap one out That is, if you know what you are doing and you don't have to DPO... |
| Hine62 |
Oct 22 2012, 05:08 PM
My dad's a mechanic and said just replace the disc. Can I upgrade to the six spring 911 disk? money is going to be tight because of the hell hole repair that is being done soon... (IMG:style_emoticons/default/sad.gif)
| JamesM |
Oct 22 2012, 10:57 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,183 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
My dad's a mechanic and said just replace the disc. Can I upgrade to the six spring 911 disk? money is going to be tight because of the hell hole repair that is being done soon... (IMG:style_emoticons/default/sad.gif) I have installed a used pressure plate before... wont do that again. Last 2 times I have ordered "914" discs they have showed up with 6 springs |
| rhodyguy |
Oct 23 2012, 10:26 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
add a new throwout arm pivot clip, the ball cup bushing(recessed in the throwout arm), and the 2 plastic throwout bearing retaining pieces to your parts list.
Lo-Fi Version | Time is now: 9th March 2026 - 10:33 PM |
