Can I get a some input on repairing the engine mount?, Found some thin spots ..................... |
cary |
Dec 7 2012, 06:53 AM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
I was wondering if I can get some input or BTDT on repairing this engine mount.
Looks like moisture can slip in behind the mount because of the lack of seam sealer at the top. (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) The sides that secure the engine seem fine. Just wondering what other folks have done. |
nathansnathan |
Dec 7 2012, 07:25 AM
Senior Member Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
A driver side piece should be in much better shape. The piece that welds to the bottom is different, but besides the filter mount, they are the same, the piece you got there.
mepstein |
Dec 7 2012, 07:53 AM
914-6 GT in waiting Group: Members Posts: 19,315 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Scotty B does one on this thread.
http://www.914world.com/bbs2/index.php?sho...183248&st=0 Attached image(s) |
cary |
Dec 7 2012, 12:55 PM
I thought I remembered one. But I couldn't find it.
nathansnathan |
Dec 7 2012, 03:06 PM
Mine was not as bad as yours is, but I didn't like the pitting, especially down in the nook between the 2 pieces. On the left is the driver side lower from my parts car, and below, the passenger side lower that I made in progress.
(IMG:http://www.914world.com/bbs2/uploads/post-11782-1340431571.jpg) I used the inner bottom from the driver side, too, just had to make the inverse of the part that mounts below the long (IMG:http://www.914world.com/bbs2/uploads/post-11782-1340431766.jpg) This was all months ago. I still need to smooth it out. I can make this look almost seemless with a bit more of the roloc disc. (IMG:http://www.914world.com/bbs2/uploads/post-11782-1341761216.png) (IMG:http://www.914world.com/bbs2/uploads/post-11782-1341761347.png) I need to blast off the final bit of pitting there and fabricate the flange on the lower right there. (IMG:http://www.914world.com/bbs2/uploads/post-11782-1340431904.jpg) I have to take the filter mount off the other and put it on this one, too. (IMG:http://www.914world.com/bbs2/uploads/post-11782-1340432002.jpg) |
worn |
Dec 7 2012, 03:30 PM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I was wondering if I can get some input or BTDT on repairing this engine mount. Looks like moisture can slip in behind the mount because of the lack of seam sealer at the top. (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) The sides that secure the engine seem fine. Just wondering what other folks have done. I recently removed a couple of them for a 914-6 conversion. It is a '73. The donor car has some rust issues of its own, but I as I remember the mounts were good. You can have em. I am flying to Seattle in a little more than a week and if that helps I can pack them with. I know seattle ain't oregon. (IMG:style_emoticons/default/welder.gif) |
worn |
Dec 31 2012, 01:41 PM
I was wondering if I can get some input or BTDT on repairing this engine mount. Looks like moisture can slip in behind the mount because of the lack of seam sealer at the top. (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) The sides that secure the engine seem fine. Just wondering what other folks have done. Hi Cary, Now I am at a real computer I can show you what I can send. Here are the two mounts. As expected, pits in the passenger side after sand blasting Here is the pattern and 12 gauge steel for the fix. Now here is a picture of the part welded The driver's side isn't rusted enough to worry about. Want em? I am not a pro welder, but they are free. I need to know that you want them before I go to the PO though. Warren |
cary |
Dec 31 2012, 10:35 PM
They would be great.
I'm transferring stores. I'll PM the address on Wednesday. |
Lo-Fi Version | Time is now: 9th June 2024 - 01:28 PM |
