| Harpo |
Dec 9 2012, 05:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Good evening everyone
For those of you with large compressors what kind of lines are you running through your garage? Thanks David |
| rudedude |
Dec 9 2012, 05:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 551 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest
I put 3/4" pvc in when I did mine fully intending to put in cast iron in the near future. That was like 8 years ago and I've never had any issues. I put cast iron at the ends to mount gauges and filters and secure to wall. It was fast and cheap.
| quadracerx |
Dec 9 2012, 07:30 PM
Member ![]() ![]() Group: Members Posts: 428 Joined: 3-July 06 From: WA Member No.: 6,366 Region Association: Pacific Northwest |
I was thinking about using this:
http://www.rapidairproducts.com/store/shop...mp;cat=Rapidair But havent done it yet...most every review seems to be positive and it seems simple to put in... Just a thought... Steve |
| Dr Evil |
Dec 9 2012, 07:35 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
PVC, no need for metal.
| 914GT |
Dec 9 2012, 07:39 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,101 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
3/4"copper. Metal pipe helps condense out moisture.
| yp914 |
Dec 9 2012, 07:50 PM
typ914 ![]() Group: Members Posts: 6 Joined: 27-October 12 From: Ga Member No.: 15,086 Region Association: South East States |
I am getting ready to do the same thing in my basement garage. I would definitely not go with metal pipe. It will rust from condensation in the line. It may take a while but it will happen, even with galv pipe. Copper pipe is an option except for the cost. PVC in my opinion is the best and most cost effective option. Simple to install readily available. Some people suggest PVC can't handle the PSI of a compressor but if you check the specs on PVC, you will see that it will the pressure.
My question is about sound insulation. I am putting my compressor in a closet and want to insulate the closet to keep the noise down. Any suggestions? |
| mrbubblehead |
Dec 9 2012, 08:29 PM
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
copper. super easy to make changes and way safer than pvc....
| IronHillRestorations |
Dec 9 2012, 08:32 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,920 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
Plastic is much easier and cheaper, as long as you don't have a big powerful compressor. Just make sure you use at least schedule 40.
Iron is better for moisture control and more durable, and the pro's choice. The best would be galvanized but that's really pricey. I've never seen copper used much at all. |
| shuie |
Dec 9 2012, 08:54 PM
Member ![]() ![]() Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
I just completed hooking up a 60 gallon unit with 1/2" black iron throughout my garage. It probably wasn't worth the expense and hassle for what I am doing but it is done and seems to work well. I get to spray some primer with the system for the first time this week so hopefully it was worth the effort.
If I ever have to start a project like this over I will probably do it in PVC. The black iron pipe from lowes was a PITA to work with. I had a couple of leaky fittings and had the piping system apart 3 different times before finally getting everything sealed properly. I would also build a compressor house outside of the garage for the unit if I do this again. Another thing I would like to do is route the drain lines through the wall and out of the garage. I still need a better & more accessible drain on the compressor tank, too. Here are a few quick pics of the lines and my drops.. 60 gallon single stage compressor, unregulated outlet for tires, kids soccer ball, etc.. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-2075-1355184608.1.JPG) 1st regulated drop over workbench & near the front of the car. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh5.googleusercontent.com-2075-1355184610.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-2075-1355184635.1.JPG) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-2075-1355184610.3.JPG) 2nd regulated drop on the other end of the car. (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-2075-1355184610.4.jpg) |
| wingnut86 |
Dec 9 2012, 09:00 PM
...boola la boo boola boo... ![]() ![]() ![]() Group: Members Posts: 1,054 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
I went black steel pipe - Chinese cast iron basically. Hard to find good American made black pipe these days. If I had known how many junctions, 45s and 90° pieces were going to be defective, I would have installed copper.
It's tricky down South with the high heat and humidity. If it's in a garage, with great airflow and somewhere to draw cool air from, expect temps to hover between 90° to 105° under cover. You need the metal for the condensation, or at least long vertical to horizontal runs with drains as often as feasible to purge air and the water (large compressors). I have multiple driers and filters and a 2' long by 2' wide silicone drier/stack that is a basic steel tube with beads for absorption at my last stage before my dry air. And, I still have another drier bolted to the side of my Skat Blaster (IMG:style_emoticons/default/confused24.gif) I like the new 3/4 RapidAir, looks solid. Michigan is different in weather, humidity, etc., so my setup is a stretch for you David. I'd give my good car away for a temperature controlled garage with exhaust vacuums and a DRYer compressed air route... We can dream (IMG:style_emoticons/default/biggrin.gif) |
| biosurfer1 |
Dec 9 2012, 09:04 PM
Teener fo Life! ![]() ![]() ![]() ![]() Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
I would never use PVC for air compressor lines. At 40 psi, you're fine but if you run it at 100 psi like most people, you run a much higher risk of fracture. I know it's not common but I've seen the aftermath of PVC pipe blowing apart (trying to find the garagejournal.com thread) and there were shards sticking half way through drywall. Knowing my family walks through the garage, not to mention myself, an seeing those pictures makes it worth the extra cost to run hard lines.
| 76-914 |
Dec 9 2012, 09:15 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,866 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
3/4 pvc is certainly strong enough to handle 125psi but the issue is with how the pipe explodes, if you will. when blk, galv or copper pipe/ftg's break it doesn't propel flying shrapnel like pvc can and does. i'll bet Rick or one of the other ins adjuster's here can tell some stories. condensation is going to happen no matter what pipe material is used. most importantly, installation is the key. vertical drops should have a 6" drip leg with a hose bibb on the end to drain. air outlet should come from a tee ftg at least 6" above the end of the drip leg. all horizontal lines should be installed with enough slope as to allow for proper drainage back to the vertical drop preceding it. in other words don't give the pipe a place to trap the water. if you do use pvc do not expose it to sunlight as UV rays deteriorate the material and know that the psi ratings for pvc aren't the same at 30F as they are at 70F. slap a piece of pvc pipe against a brick on a freezing day.
| mrbubblehead |
Dec 9 2012, 09:18 PM
Plastic is much easier and cheaper, as long as you don't have a big powerful compressor. Just make sure you use at least schedule 40. Iron is better for moisture control and more durable, and the pro's choice. The best would be galvanized but that's really pricey. I've never seen copper used much at all. i have seen pvc get brittle and explode in a guys face at work. not pretty. galvanized isnt recommended because over time it flakes off inside and plugs your filters. personally i would never use pvc for a permanent installation. copper and black iron (natural gas type) are recommended. black iron is probly the best. its extremely durable. but a real pain in the ass because it has to be cut and threaded and then spun together. and that makes changes even more of a pain in the ass. thats why i went with copper. easy to install. its durable enuff for a home garage. and it makes changes a snap. but these are all just my opinion. that said, i have a buddy who ran his home system in pvc schedule 40. and has had no problems. i think it is a ticking time bomb. literally. i have maybe 200 dollars into my system so far and i am useing blu copper from home depot. i am doing my system in stages. i have the back bone in and 2 drops so far. one more drop for my blaster cabinet and its finished. (IMG:style_emoticons/default/first.gif) |
| Dr Evil |
Dec 9 2012, 09:30 PM
I have been running my 80 gal through sc40 PVC at upwards of 110psi with no issues.
| cary |
Dec 10 2012, 01:10 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest
I'll make it even more confusing. I ran Schedule 40 PVC overhead from the compressor. But I converted to black pipe on all the pipe going down to the outlets.
I have a switch for the compressor at the door. I turn it off when I leave. So its only charged up while I'm there. |
| VaccaRabite |
Dec 10 2012, 05:13 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,840 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
I'll make it even more confusing. I ran Schedule 40 PVC overhead from the compressor. But I converted to black pipe on all the pipe going down to the outlets. I have a switch for the compressor at the door. I turn it off when I leave. So its only charged up while I'm there. Unless you drain the compressor or your pipes leak or your regulator is at the compressor and not at the drop the pipes are charged all the time. Zach |
| edwin |
Dec 10 2012, 05:24 AM
Member ![]() ![]() Group: Members Posts: 321 Joined: 20-May 09 From: Australia Member No.: 10,384 Region Association: Australia and New Zealand |
Our shed at home is done with copper
I'm glad because I had a teacher at school go liked having fun blowing stuff up an watched a small piece of pvc fracture under working pressure. Small scratches etc are nasty |
| GaroldShaffer |
Dec 10 2012, 06:48 AM
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,643 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None
I was thinking about using this: http://www.rapidairproducts.com/store/shop...mp;cat=Rapidair But havent done it yet...most every review seems to be positive and it seems simple to put in... Just a thought... Steve I have that in my garage works just fine with my big compressor. Easy to install. |
| Zimms |
Dec 10 2012, 06:54 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,415 Joined: 11-February 06 From: Michigan Member No.: 5,565 Region Association: Upper MidWest
I went with aluminum from Garage Pak Garage Pak. We used it in a shop large machine shop I worked at (36+Swiss machines), never had an issue, and went from having a mess of conduit and hours to add a drop, to minutes with tidy looking blue lines.
It was not the cheapest, and it's overkill for my use, but it is easy in every sense. Easy to put up, easy to add drops, and easy to move if you end up going anywhere. I moved everything from my garage to a shop and was glad I had it. The compressor I have is a 5 hp, 2 stage with an 80 gallon tank. |
| Mark Henry |
Dec 10 2012, 07:22 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I still have to do this and it will be black pipe because I run at 160lbs. I had black pipe all through my old shop and most of it is here waiting to go up.
The big thing if you run black pipe is you are suppose to have a drip leg at every drop. Not only water collects in the drip leg but so does any flakes of rust. BTW although it will just have a cap, a drip leg is code on all gas line black pipe drops. Go look in your basement if you have gas. Not my pic but a good image of a black pipe drip leg: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.2002tii-restoration.org-26-1355145733.1.jpg) |
Lo-Fi Version | Time is now: 7th March 2026 - 05:07 AM |
